Oil leak at rear under car
Old Aug 24, 2002 | 09:54 AM
Avi's Avatar
Avi
Default Oil leak at rear under car
Just wanted to share my surprise to find an oil leak in the rear of my car. Took it to Marin Honda. The car was inspected and we found the rear left bushing was leaking oil. No one new that the bushings have oil in them. Honda wanted to replace both the left an right bushings even though only the left was leaking. Yesterday I took the car back and the two bushing were replaced. Honda wanted the old bushings sent Federal express to their tech dept. for investigation. I guess it is the first time that failure happened. My car has 7k miles.
Old Aug 24, 2002 | 10:22 AM
CoralDoc's Avatar
Bushings? Is that what it says on the repair order?
Were these the half shafts (Honda calls them drive shafts), or possibly the wheel bearings? Either of these would leak grease, not oil though. The only items in the back of the car with oil in them are the differential (smelly oil) and the shocks (very light oil).
Old Aug 24, 2002 | 12:17 PM
Avi's Avatar
Avi
It is Bushings parts #6384275 rubber AS 50730-S2A. Te job description was"Remove exhaust mufflers, lowered differential& replaced left &right Bushings". The Job was done under warranty.
Old Aug 24, 2002 | 02:01 PM
Flyin Wedge's Avatar
If it's rubber they will dry out and crack,someone on this forum told me about spraying the rubber with a rubber safe silicone spray to help keep them conditioned.
Old Aug 24, 2002 | 05:36 PM
SkipX's Avatar
I had the same thing happen to my car. Its handling went out the door. It felt like the car had flat on the left rear. I had mine replaced under warranty.
-Skip
Old Aug 25, 2002 | 03:21 AM
2kturkey's Avatar
Originally posted by SkipX
I had the same thing happen to my car. Its handle went out the door.
So how do you open the door now - or did you mean handling??
Old Aug 25, 2002 | 03:45 AM
CoralDoc's Avatar
[QUOTE]Originally posted by Avi
[B]It is Bushings parts #6384275 rubber
Old Aug 25, 2002 | 04:22 PM
SkipX's Avatar
Are you happy now?
Old Aug 26, 2002 | 01:21 AM
2kturkey's Avatar
Are you happy now?
Yes
Xeon
Oct 6, 2016 07:19 AM
oscarmamamia
Mar 24, 2014 03:52 AM
thirstys2k
Feb 20, 2009 03:34 PM
johnyboy32
Jun 14, 2003 04:47 AM
