Remote trunk release with key in ignition?
Old Nov 29, 2004 | 09:26 AM
HOTRODS2000's Avatar
Default Remote trunk release with key in ignition?
I've done multiple searches and tried looking in the FAQs. Can someone tell me how/which wire to cut /modify to enable the keyless remote to unlock the trunk with the key in the ignition? Thanks.
Old Nov 29, 2004 | 12:25 PM
User 53024's Avatar
http://www.baustnet.com/honda/mods/trunksw/trunksw.htm
Old Nov 29, 2004 | 12:32 PM
modifry's Avatar
Honorary Member
I can see two possible places where the Keyless Entry module could get a signal when the ignition is ON. One or both of these may be what disables the Keyless functions.
First, there is a yellow wire that is hot when the ignition is ON. There are 2 yellow wires on the Keyless module, the one you want is NOT at the edge of the connector.
Second, there is a red/white wire that is grounded when the key is inserted into the ignition lock. (only one red/white)
I would check and see what disables the Keyless functions. If simply inserting the key (leaving ignition OFF) disables the Keyless functions try cutting the red/white wire.
If they keyless functions still operate with the key inserted and only stop working when the ignition is ON, try cutting the yellow wire.
Let us know which one works.
Cyclon36
Apr 26, 2018 09:06 PM
shepp
Sep 9, 2009 09:35 AM
AP1rulz
Jun 24, 2008 03:52 PM
GTAS2000
Feb 11, 2002 10:40 AM
stookfreak
Jul 30, 2001 02:25 PM
