Vortech owners - Watch out!
Old Aug 1, 2004 | 03:38 PM
xviper's Avatar
Default Vortech owners - Watch out!
On my last road trip, I checked my engine bay for anything odd. I usually do this as part of my oil check routine on a long trip. I noticed that the BOV filter was actually putting an indent into the AC metal line. Thank goodness I found it before it wore a hole right through it. I removed the filter till I got home.
Here are some pics to show what it looks like and what I did:
First one is of the worn away part of the metal line through the foam insulation:
Next two show what I did to resolve the issue. Vortech shows to install the BOV with the filter pointing down. I removed the BOV and turned it upside down and re-installed the filter:
I have filled in the indent and worn away foam insulation with a big glob of clear silicone seal. Black would have been nice but I didn't have any.
I highly recommend you go check this aspect of your installation and attend to it as necessary. I also recommend that all those who are about to install a new Vortech put the BOV as shown in my last two pictures.
Old Aug 1, 2004 | 03:55 PM
Slows2k's Avatar
I have about 10mm clearance on mine. My aftercooler is pretty upright with the AN fittings though.
Old Aug 1, 2004 | 04:48 PM
xviper's Avatar
It's odd that they don't all sit the same. My cooler is angled down to toward the blower, thus making the filter touch the AC line.
Old Aug 1, 2004 | 06:07 PM
Slows2k's Avatar
The silicone connection sleeves allow a very little amount of play. My aftercooler is pushed as far back towards the throttle body so the different fittings I used don't hit the radiator.
Old Aug 1, 2004 | 06:08 PM
Slows2k's Avatar
Old Aug 1, 2004 | 07:05 PM
xviper's Avatar
The angle on mine doesn't look much different than yours and my filter was pushed as far as possible onto the BOV mounting base.
Old Aug 2, 2004 | 02:25 AM
MechaGodzilla's Avatar
Interestingly, I discovered this exactly one year ago and was similarly alarmed.
https://www.s2ki.com/forums/index.php?showt...0&#entry2053839
MG
Old Aug 2, 2004 | 04:49 AM
Mirror's Avatar
yeah that's where I learned about a year ago. I found that if you turn the filter 90 degrees it does the trick.
Old Aug 2, 2004 | 05:27 AM
bigpurp's Avatar
Thx for the heads up, x-man and mecha.
I will go out and check mine tonite...
Old Aug 2, 2004 | 05:28 AM
xviper's Avatar
How'd I miss that one? Wish I'd seen it then.
