Weight reduction: What are the best mods?
Hey guys,
I have been tracking my 2005 and generally have been very pleased. The only mod I have done so far is a set of Tein coilovers.
I want to reduce the weight of the car by a couple of hundred pounds. What do I need to do to make this feasible?
Where can I save the most weight?
Thanks in advance
Tony
Thanks in advance
Tony
pull out your interior. I did mine tonight, and must have taken 200lbs out of the car:
http://tastybeef.com/s2k/s2k-interior2.jpg
It looks prettier in my spare bedroom:
http://tastybeef.com/s2k/s2k-interior.jpg
Brian
Brian
-3 Mats/Visors
-30 (5 Gal Gas)
-12 Optima PC600 Battery
-15 Recaro SPG
-32 Remove passenger seat
-18 Tein RAs
-5 Center Console
-10 Stock Rollhoops/Plastic
-2 Washer Fluid
-3 Cruise control unit
-30 Wilwood Dynalite Brakes/Rotors
-1 Hood insulator
-5 Flywheel
-10 T1R test pipe (no cat)
-20 AC Compressor + lines + Radiator + Fluid
-5 AC Evap Core + rubber hose
-20 Stripped Hard top
-8 Rear sway bar
-15 Volk CE28s
-15 Header
-15 Dash
-15 Airbags
-6 Wipers/motors
-30 Gutted doors
-30 (5 Gal Gas)
-15 Recaro SPG
-18 Tein RAs
-5 Center Console
-2 Washer Fluid
-1 Hood insulator
-5 Flywheel
-8 Rear sway bar
-15 Volk CE28s
-15 Header
-15 Dash
-15 Airbags
-6 Wipers/motors
-30 Gutted doors
Originally Posted by Ludedude,May 27 2006, 02:10 AM
Sorry, I had to.
Originally Posted by Nobody,May 29 2006, 08:16 AM
-30 (5 Gal Gas)
Originally Posted by Ludedude,May 27 2006, 01:10 AM
The first things I would do, would be...
remove spare, tools, get lighter rims and exhaust
I have single exhaust with test pipe -60lbs
gutted trunk -42 lbs
J's header -13 lbs
emptied windshield washer reservoir -8 lbs
cold air intake -3 lbs
coilovers -12 lbs
SSR Comps -16lbs
drycell battery -15lbs (I'm locating mine in rear to help with weight ratio - most is removed from rear so rear end can get trigger happy sometimes too often)
I will also be removing my front bumper support, which is supposedly another 12-15 lbs. I will leave in the rear because I do not want to take out any more weight out of the rear.
I just need to figure out another 15-20 pounds and I'll reach my goal of -200 pounds before gasoline. Maybe CF mirrors? How much do stock mirrors weight?
I only fill up with 10 dollars worth of gas at a time, which is usually only 3 gallons so I'm saving another 60-70 pounds there.
Good luck with your weight savings.
J's header -13 lbs
coilovers -12 lbs
SSR Comps -16lbs
