Air Pump removal=check engine light, anyway around the CEL?
Old 04-09-2003, 06:14 PM
vapors2k's Avatar
Default Air Pump removal=check engine light, anyway around the CEL?
Air pump was removed, this helps get the cat heated up faster on cold starts. I removed everything in that area, the pump and what looked like to be a relay. First start of the car and all is fine. After the second start, check engine light pops on.
To those that have removed the air pump, do you get a check engine light?
tia,
-ardy
Old 04-09-2003, 06:22 PM
Prolene's Avatar
Krazik removed the air pump as well and says everything was fine at BW, though the CEL was lit. I know of no workaround for the light. I'm not sure what I'm going to do if I put the stock ecu back in, since the Mugen ecu does not set off the CEL for this.
Old 04-09-2003, 06:25 PM
vapors2k's Avatar
the CEL didn't affect the car in any way. Damn the CEL, I was CEL free until now. I might as well try that test pipe and see where I'll be.
Old 04-09-2003, 06:32 PM
Prolene's Avatar
That test pipe might cause a limp home mode...or just cel... or tune issues?
Old 04-09-2003, 07:34 PM
coquinn's Avatar
You just get the light w/ a test-pipe ...no limp mode (at least here on the east coast).
You still get the light w/ the Spoon ECU as well if you have a test-pipe ...still trying to figure that one out.
Old 04-09-2003, 08:00 PM
bheeter's Avatar
Do you want to sell your air pump assembly? I'm in need of a new one, and it doesn't sound like your using yours. Let me know.
Old 04-09-2003, 09:10 PM
SsamJang's Avatar
i havent had my airpump taken out.. but i disconnected it and put it back together and nows its giving me a check engine line.. for incorrect secondary flow or something like that.. this is the second time.. once when i had my CAI and now with my turbo.. i know that the airpump is for emissions.. i would also be interested if there was a way to bypass that CEL from removing the airpump
Old 04-09-2003, 10:04 PM
vapors2k's Avatar
Old 04-09-2003, 10:05 PM
vapors2k's Avatar
[QUOTE]Originally posted by bheeter
[B]Do you want to sell your air pump assembly?
Old 04-10-2003, 05:44 AM
Gernby's Avatar
How many wires (pins) are in the air pump's harness. If there are only 2 wires, then I think the ECU just checks for a current load from the air pump. The only way to fool it would be to find a REALLY high wattage resistor to put accross the air pump's power leads. If there are more than 2 wires, then it could be more complicated (fan motor RPM wire, etc.).
Quick Reply: Air Pump removal=check engine light, anyway around the CEL?
