Installing trunk spring. (pic)
Old May 3, 2003 | 09:52 PM
stockae92's Avatar
Default Installing trunk spring. (pic)
I've got the trunk spring remover for quite some time already and I finally got the time to install the heavy duty trunk spring that comes with the OEM trunk spoiler.
Here is what I did:
First remove the the clips that holds the spare tire cover and the left trunk side trim panel.
Here is the trunk spring remover
Use the trunk spring remover to take off the trunk spring. Its not that hard to remove the trunk spring with the right tool.
Putting the new spring back on is almost the exact opposite of what you did to remove them. I rest the trunklit on my back when removing and installing the spring.
Job done. Just make sure it works and looks the same as before you began to install the trunk spring
This is one of the easier mod/upgrade to do. If you got the right tool, its almost a no brainer.
In fact, I installed 1 heavy duty trunk spring and 1 regular trunk spring. I found that with both heavy duty trunk spring installed, the trunk pop up too strong when opening all the way. With this set up, I am with the amount of force it pop open the trunk and it's not too strong when opening it all the way.
Old May 4, 2003 | 04:43 AM
silverbullet02's Avatar
does the tool come in the car?
Old May 4, 2003 | 12:30 PM
TriaXenginE's Avatar
jon, the tool doesn't come with the car. i ordered the springs from hardtopguy(jeff) and the tool was like 7 bucks. it's invaluable because i don't know how you'd get the new springs on without it.
Old May 4, 2003 | 12:52 PM
swtazn97's Avatar
you could use a cresent wrench to remove the trunk springs, but be careful, it's scarey. You could also use one of those horseshoe looking wrenches to install the trunk springs.
Old Nov 27, 2007 | 10:55 AM
jyeung528's Avatar
small hook, goes into hinge hole from the top inside part of the hinge. ie: the inside of the bowl if you look at the hinge it looks bowl shaped. so the end of the hook is on the outside of the bowl.
large sq hook is now upside down. put tool upside down on upside down hook.
now rotate tool towards you all the way until big hook does a 180 and open end is pointing down.
now slip it on the hook retainer and make sure it locks in place before you let go.
if you let go to soon, it's gonna hurt.
Old Nov 27, 2007 | 03:13 PM
RadioZero's Avatar
^^ whoa dude (jyeung528), you copy and pasted my post from another thread with no credit given. this is complete plagiary.
https://www.s2ki.com/forums/index.php?showtopic=545655
Old Nov 27, 2007 | 03:22 PM
Mugen_EP's Avatar
SUE HIM!!!
Old Nov 27, 2007 | 03:35 PM
jyeung528's Avatar
HAHA...
i was going to explain with another post but was too lazy...
i read your post first and liked the description...then i saw this post with the pictures.
so i wanted to print this thread WITH you post...so instead of printing both threads...i just copied an pasted and PRINTED for my own personal use.
LOL.
don't be mad.
Old Nov 27, 2007 | 03:37 PM
Shadow_S2K's Avatar
I even linked this thread also...but anyone have any idea how the S2000 Trunk spring remove is suppose to be held? The same way? But its designed differently.
This is the tool that I have
Old Nov 27, 2007 | 04:17 PM
RadioZero's Avatar
jeez, it's the same tool as the above pics but without the little V thing. if you can't figure this out from all the pics and info provided, you need to pay the dealer to do this..
oh and Mugen_EP, my A.
