bose rsx sub - how do i make this work with my rca cables
Old Jul 1, 2003 | 10:41 AM
Bass's Avatar
Default bose rsx sub - how do i make this work with my rca cables
pre ran rca jacks to the rear of the but on the sub there's a plug
anyone know what harness i need?
Thanks
Old Jul 1, 2003 | 12:16 PM
usace's Avatar
I have a feeling it's meant to run off of high level (speaker level) inputs rather than low level (rca's) inputs. Don't quote me on this though. You may want to PM someone that has already done this install.
Old Jul 1, 2003 | 12:19 PM
Bass's Avatar
ok not too sure what you mean as i'm far from an audio expert..
Thanks
I also have rear speakers and a sub line from my HU (but i mentioned that already)
Old Jul 1, 2003 | 03:14 PM
usace's Avatar
What I mean is that instead of hooking up the sub to your rca's you may have to hook it up to your rear speaker lines. It looks like the wires showing in the picture may be a power, switched power, and ground for the amp and then a positive and negative for supplying the audio signal from your HU. Again, don't quote me on this. A lot of amps give you the option of using rca's or speaker inputs (in this case your rear speaker lines). I really hope someone chimes in here and confirms this for you.
Old Jul 1, 2003 | 06:58 PM
mgiang7's Avatar
bass,
i think you're missing a part. send a PM to JasonB, i know he just hooked one of these up--i can't find the thread but he got it working.
Old Jul 3, 2003 | 11:33 PM
revhi's Avatar
Really if I knew the bose would work some how in the S, I wouldn't have gottan subs. I thought it needed the Bose head unit too.
Old Jul 4, 2003 | 12:29 PM
Dr.Evil's Avatar
JasonB is the one to talk to about this. I think you either need a harness or you need to solder the wires into the head unit. Good luck ~
Old Jul 6, 2003 | 03:04 AM
Bass's Avatar
Thanks guys... Bass pictures the old gray hound comerical in his head " I've got my best guys on it right now" three guys sitting on the hood eating lunch
G-s2k took my car this weekend and he was going to have a look so hopefully all is good
revhi nope no need for a Bose HU the system has an amp bulit in
Old Jul 6, 2003 | 10:53 AM
Bass's Avatar
Bass (as in the fish) now has Bass (as in deep sound) Thanks Glenn sounds great
Old Jul 8, 2003 | 04:41 AM
g-s2k's Avatar
