Hardwiring Radar Detector
Old Nov 17, 2000 | 11:04 AM
S2K_CLS's Avatar
I looked on S2ki, but the link to V1 mounting was not working...
so, I gather there are some usable fuses in the interior box that can take care of this...
Any advice on how to do a first rate job (ground points, etc)...
thanks!
Old Nov 17, 2000 | 11:21 AM
RossoS2K's Avatar
Under the dash, the fuze box has 3 "plugins" one is hot always, one is hot while ign is on, one is hot with the headlights.
I hooked mine to the hot with ingition, grounded it to a nearby bolt, and ran the wire up over the dash to the detector.
some one will be able to tell you which plugin is which, I dont recall at the moment
Old Nov 17, 2000 | 11:26 AM
Sunchild's Avatar
For those that ran the cord up to the "window shades", did you have to pull the a-pillar trim off? Also, does the fuse box accept a blade connector, or how does one splice into that fuse?
Old Nov 17, 2000 | 11:33 AM
Schatten's Avatar
hmmmm, just noticed the broken link. not sure where it was linked to or where to obtain the original files. the link is pointing to http://216.62.52.233/v1mount.htm, but not even the IP's root page comes up, but it does respond to a ping.
If you've got any pictures or would like to write up something to be posted on s2ki.com about hardwiring the V1, please email me. Thanks!
Old Nov 17, 2000 | 12:23 PM
josh3io's Avatar
i used the wire clip and jacked onto the big yellow wire uner the driver dash. not wrapped in yellow tape, but yellow wire. it's hot only when ignition is in II.
Old Nov 17, 2000 | 01:43 PM
S2K_CLS's Avatar
hey guys...
thanks...
I will check it out most likely tomorrow and see what I can see...
Need to practice my contortionist skills
Old Nov 17, 2000 | 07:17 PM
kcopp's Avatar
I wouldn't use a wire clip. I would use one of the extra connections in the fuse panel so you are less likely to damage something. You will love your V1. I can hardly drive without it!
Old Nov 18, 2000 | 05:50 AM
Red_s2k's Avatar
the v1mount page is mine... sorry some bad guys decided to use it as leech site to store 500mb of crappy japanese cartoon files!! I took it down because I made them mad when I killed the ftp side... I will try and repost it to my providers web page asap.
Old Nov 18, 2000 | 05:51 AM
Red_s2k's Avatar
an by the way... I had no idea that link had made it to s2ki's page...
klein1223@mac.com
Oct 27, 2008 02:37 PM
basslover911
Mar 28, 2006 04:15 PM
basslover911
Mar 11, 2006 10:31 AM
Nottm_S2
May 10, 2005 04:00 PM
Tfunk
Apr 16, 2001 11:19 AM
