disconnect door chime???
Old Nov 28, 2003 | 05:05 PM
hirev's Avatar
Default disconnect door chime???
can anyone tell me exactly how to disconnect that chime every time i have the door opened with the key in the ignition...i know it makes a cute little Morse H, and that if I remover the key it will stop, and that some folks like it...i have read that...i would like to know exactly how to take it out...
in my acura i disconnected a chime by pulling a wire, in my volvo is was a fuse, in my miata it was a wire in the column...what is it and where is it in my S2000, 04?? Thanks
Old Nov 28, 2003 | 05:44 PM
fantaS2K's Avatar
Found this diagram:
Old Nov 28, 2003 | 06:14 PM
Slows2k's Avatar
The above diagram is for the drivers door lock actuator. If you don't want drivers power lock to work, You can unplug it there. The buzzer is built into the instument cluster. To make the dinging go away, You would have to unplug the ignition key switch connecter. Remove the 3 screws under under the steering column lower cover. The really fun part is removing the cover without breaking any of the locking tabs. Push in on the lower cover, and work your way around the cover pulling down. Cursing occasionally also seems to help persuade the cover. The connector is green, and has 2 wires, and 5 unused cavities. Don't unplug the immobilizer reciever connector right next to it. (Car won't start) That should make the dinging stop.
Old Nov 28, 2003 | 06:19 PM
fantaS2K's Avatar
I would rather just close the door.
Old Nov 28, 2003 | 06:25 PM
Slows2k's Avatar
Another option, Remove the key. That's what the dinging is for.
Old Nov 28, 2003 | 06:29 PM
fantaS2K's Avatar
How do you know how to do it. Did you have to do it yourself?
Old Nov 28, 2003 | 06:32 PM
Slows2k's Avatar
I work on honda's for a living. I like the dinging. It keeps the keys in my pocket.
Old Nov 28, 2003 | 06:38 PM
fantaS2K's Avatar
Yea. I wonder why would someone want to get rid of it.
Old Nov 28, 2003 | 09:36 PM
BryanH's Avatar
Some of us enjoy the freedom of being able to have the key in the ignition (radio on or what have you) with the door(s) open, without a beep or buzzer to annoy us.
In my 7 years of driving (admittedly not much) I've never locked my keys inside. The first thing I did to my car when I got it in '99 was remove the door ajar buzzer.
Old Nov 28, 2003 | 09:44 PM
fantaS2K's Avatar
Now that you mention it, it does kind of makes sense. I can see myself going to the beach, lay down on the sand, watch the sky and listen to some music with door open. Nice.
