Remove the catalytic.....
Hey all,
I was told that the S2000 catalyst is a metal cat, not ceramic. It supposedly is much more free flowing than the older technology, and MUCH more expensive.
You may have nominal gains at best, probably nothing worth writing home about.
-Nick
-Nick
BlueS2000-
It sounds like you've already made up your mind.
Metallic catalysts are different from the ones in your brother's Civic and your neighour's Integra. Those are ceramic- completely archaic compared to the metal type. I also wouldn't base modifications on what works on a Civic based platform- like I wouldn't install a 4-1 header on the S2000, although that is THE header design of choice for the Type R.
Good luck on getting those 8HP out of a test pipe. I look forward to hearing about your exploits with this modification.
-Nick
-Nick
