Remove the catalytic.....
Old Nov 24, 2000 | 11:36 AM
shaner's Avatar
I have ordered the resonator-straight pipe from MG Racing to complement my Mugen headers (on order) and aftermarket exhaust for more free flowing exhaust... I hope that it helps.
Will I see a "check engine" light on due to the lack of catalyst?
Thanks!
Old Nov 24, 2000 | 01:57 PM
RandyP's Avatar
OK, for those of you that are polluting the earth in search of more horsepower, you owe the rest of us a before and after dyno. And I don't mean a Pinky's seat-of-the-pants dyno
Old Nov 24, 2000 | 08:19 PM
GTRPower's Avatar
Shaner-
Yes. Unless you use a competition ECM that eliminates the catalyst O2 sensor.
-Nick
Old Nov 24, 2000 | 10:39 PM
mingster's Avatar
I'm getting the BYS pipe from 1RandyC, I wonder if he had the engine light go on...
Old Nov 25, 2000 | 04:08 AM
BlueS2000's Avatar
I
Old Nov 25, 2000 | 07:58 AM
1Randyc's Avatar
mingster and others who are contemplating on removing catalytic converter please pay attention to this warning!
I certainly gained something by using the BYS straight pipe in place of the catalytic converter.
However........
Two days ago I removed the Mugen ECU and replaced it with stock ECU. The car immediately felt loss of power and vtec didn't engage at all. I thought it was FPR and I fooled around a little bit. As the day go by the car started to run poorly with some hesitations and yesterday on the way from work I got the check engine light.
And today I replaced all the exaust system with stock system as well as the catalytic converter in place.
I still have to go to Honda dealer to reset the trouble code since simple ecu reset will not clear the check engine light but the car is now running better.
I will not run hard as of yet until if the check engine light is indeed for sure induced by removing the cat, but I am sure it is.
So, if you do not have performance ECU like Mugen this upgrade is out of the question.
I will give you guys more update, so....
Old Nov 25, 2000 | 08:40 AM
Prolene's Avatar
Thanks for the "heads up". How did you try to reset the code? By removing fuse #5 (I think it is) a little while while the car was off?
Old Nov 25, 2000 | 09:35 AM
shaner's Avatar
1RandyC,
How much was the Mugen ECU and where did you get it from? So, if I am getting the cat replacement pipe from MG Racing then I should get the ECU? What else will the ECU offer me with my oter upgrades (supercharger, headers, exhaust, bored throttle body, honed/polished intake manifold)?
I figured loosing the cat would let my exhaust from the forced induction exit easier...
Thanks!
Old Nov 25, 2000 | 02:22 PM
BlueS2000's Avatar
Let
Old Nov 25, 2000 | 02:28 PM
krazik's Avatar
Administrator
You could keep the stock ECU, just figure out what voltage the stock ECU wants to see out of the second o2 sensor, and replace the sensor w/ a resistor.
Then just plug the hole in the BYS pipe.
