California - Southern California S2000 Owners Southern California S2000 Owners
For Hockey - clutch adjustment
Old Mar 21, 2004 | 01:24 PM
ronblanford's Avatar
Default For Hockey - clutch adjustment
After Hockey and I replaced my clutch fluid, the clutch play felt different. It engaged very quickly, and left a lot of freeplay when the pedal was fully up. I wanted it to engage later and have less freeplay.
Started by reading the Helm manual.
There are three different things to adjust, but two, A/B and H/I, are for sensors that tell when the clutch is fully engaged or fully released. D/E adjusts the pushrod to the master cylinder. I looked in the car to locate the real deal.
The important distances are the height of the clutch pedal when released, F = 7.5 inches, and the travel, G = 4.5 - 5 inches. I took a rough measurement to find that for my clutch, F was about 7 inches, and G was about 4.5. Not far off what it should be, and the difference probably due to measurement error. Here are the before pictures.
I loosened the locknut by turning clockwise with a 12mm wrench. Then lengthened the pushrod by turning it clockwise with my fingers about 1 turn. Tightened the locknut again.
Checked the travel again.
Okay, not much difference, but rather than overdo it, I took a test drive. Even that small adjustment felt a lot better, so I'm leaving it alone. I didn't have to touch the A/B or H/I adjustments. Those are in really tight quarters and hard to get a wrench around anyway.
There you go, Hockey. I hope this helps you, too.
Old Mar 22, 2004 | 03:01 PM
jay619's Avatar
Very nice Ron! Maybe someone will add this to the under the hood FAQ??
Old Mar 22, 2004 | 03:49 PM
MarkS2K's Avatar
Yeah, I did this when I had my new clutch put in. I had to experiment with which way to turn the pushrod to get it to shorten and lengthen.
This is an excellent writeup on how to do it. Don't forget that if you want to push the clutch pedal out more, you ahve to loosen and adjust the bolt on top, not jus the one on the pushrod.
Old Mar 23, 2004 | 07:56 AM
After driving a couple of days, I notice the improvement. Not sure whether it's the clutch fluid change or the adjustment, but it has become much smoother to start up from a light. Shifting is more abrupt so I have to pay closer attention to matching revs.
I like.
Old Mar 23, 2004 | 11:33 AM
Hockey's Avatar
Great work Ron. I don't know how I missed your post here. Thanks for pointing my nose in the right direction.
Looks like you figured it out for all of us - fantastic.
Glad you were able to make the necessary adjustments yourself, and that it worked out is even better!
Who needs Honda techs anyway? Not this forum!
*EDIT*
I just saw the title of the thread.
Thanx Ron. Now I really don't know how I missed it.
Old Oct 29, 2010 | 11:52 AM
rocketstarter's Avatar
Well done
Old Oct 29, 2010 | 12:01 PM
Whitefire818's Avatar
Wow good job reviving a 6 year old thread
Old Oct 29, 2010 | 12:19 PM
Nicotunes's Avatar
Old Oct 29, 2010 | 12:28 PM
MegaPower's Avatar
Originally Posted by rocketstarter,Oct 29 2010, 11:52 AM
Well done
yeah
Well done
Old Jan 14, 2012 | 04:49 AM
xAgyex's Avatar
This seems easy enough a fix for 2nd gear grind. I will try it and post my pics and my findings. Thanks
