My broken differential pics...
Old Jun 29, 2001 | 08:29 PM
Wesmaster's Avatar
Default My broken differential pics...
Note the missing pieces (circled). They should look like the other side does:
One of the snapped off pieces (circled) among the other debris. Arrow shows the hole on the housing as well as lots of metal shavings. Under the debris you can see a snapped center ring:
Note the wear and tear:
Wesmaster
Old Jun 29, 2001 | 09:01 PM
Allan Haggai's Avatar
And I got flamed when I refused to do 8,000 rpm side steps with my car. Believe it now??
Old Jun 29, 2001 | 09:03 PM
TurboVtk's Avatar
Its this warrantied, also is it possible to get a different housing.
Old Jun 29, 2001 | 09:44 PM
Roceye's Avatar
Hard to tell from the pics but it looks like the bearing caps failed. Did any of the bolts break? Methinks a cap girdle is in order,
or a 9in Ford replacement.
Old Jun 30, 2001 | 12:05 AM
lvs2k's Avatar
Has any of this damage been attributed to the SC? Didn't you also break an axle earlier?
Old Jun 30, 2001 | 10:50 AM
krazik's Avatar
Administrator
[QUOTE]Originally posted by lvs2k
[B]Has any of this damage been attributed to the SC?
Old Jun 30, 2001 | 11:00 AM
Sev's Avatar
Sev
Originally posted by krazik
The same exact damage happend to Josh3io's diff and he is NOT SC'd.
I beleive more then 5-6 more differentials, that we know off, have had the same fate on non-SCd cars.
Old Jun 30, 2001 | 11:14 AM
Wesmaster's Avatar
Old Jun 30, 2001 | 11:25 AM
Moneeb's Avatar
Hey Wesmaster, are you planning to upgrade to a Kaaz LSD - do you think the Kaaz will be able to tolerate high rpm clutch drops??
Old Jun 30, 2001 | 11:13 PM
virlandez's Avatar
I'm planning on upgrading my clutch, because my current one is failing... I still plan on driving my car hard, maybe get a supercharger after the mounting bracket problem is fixed... But do you guys think that upgrading the clutch is a bad idea, and should I expect the diff to fail later..??? I've been reading a lot of bad things lately, and it's really starting to get me worried about modifying my car.. But for the meantime, I need to replace my clutch, because it keeps slipping when I run it hard. Should I upgrade, or just get an original from honda...????
