Cross posted: Trunk release not working
Old Apr 22, 2004 | 05:04 AM
SandyS2K's Avatar
Default Cross posted: Trunk release not working
Forgive the cross posting with the 'Under the Hood' section.
__________________________________________________ _____________________
Does anyone have a schematic for the wiring to the trunk solenoid?
Problem: Remote / in car trunk release doesnt work.
Notes: When I press the trunk release button on the remote, I hear a click from the keyless entry unit. The fuse for the unit is ok.
When I test the 3 wire connector to the trunk solenoid i get:
* black / blue stripe wire: +12v
* centre wire: Ground
* black / yellow wire: no reading.
I have checked this black yellow wire and it has no continuity with the other wires / nor voltage change etc. when the button is pressed. Is this wire the signal wire?
Thanks for any help!!!?
Old Apr 22, 2004 | 10:59 AM
AquilaEagle's Avatar
Administrator
Old Apr 22, 2004 | 11:00 AM
Administrator
That what you need?
Old Apr 22, 2004 | 03:50 PM
SandyS2K's Avatar
Brilliant - Thanks AE
Old Apr 23, 2004 | 01:44 AM
Administrator
I dunno what KH model is - but there is also a non KH model if you need it ?
Old Apr 24, 2004 | 10:14 AM
SandyS2K's Avatar
Thanks - that diagram helped.
Right for the record I have fixed the problem. The wires were broken where the loom is clamped to the bulkhead next to the boot hinge. I think this will happen to a lot of cars because of the movement in the loom as you open the boot and the fact that they are clamped very tightly. Mine happened first because it is one of the oldest.
doheboy6
Oct 27, 2019 12:38 PM
Ed'sS2000
Nov 9, 2014 08:00 PM
dustin02rsx
Mar 10, 2013 10:40 AM
SandyS2K
Apr 22, 2004 05:03 AM
