Stuck in a rut. 362hp/216ft lbs
Old Jun 11, 2004 | 07:58 AM
Sideways's Avatar
Default Stuck in a rut. 362hp/216ft lbs
We changed out the exhaust headers to Toda, added a dual Amuse Ti cat back and a straight pipe. Added RC 750 injectors, bumped the timing 4 degrees, raised the redline up to 9300 rpm and added 100 octane fuel. We did loose one pound of boost from the last session that would account for about 15 hp.
The results of the modifications could definately be felt by the butt dyno and probably reflect the 50+ lb weight loss since the Dynos are virtually identical. Go figure?
My conclusion is the factory exhaust is just fine for making horsepower but heavy since I was able to reduce the weight by over 50 lbs.
Looks like the next step is to install the 9 lb boost pulley for 25 or 30 hp.
Old Jun 11, 2004 | 08:03 AM
bigpurp's Avatar
Very, VERY surprised here. I would've expected at least 5-10 WHP with your recent additions + race fuel.
Oh well...at least you lost some MAJOR weight, which has to count for something.
Thx for sharing.
Old Jun 11, 2004 | 09:26 AM
mxt_77's Avatar
How did you lose 1 lb of boost?
Old Jun 11, 2004 | 09:45 AM
Hybrid901's Avatar
With a supercharger if you increase the VE (make the motor more efficient) of the motor you will lose some boost but make about the same power or more. Its happens alot of supercharged V8's with ported heads.
Old Jun 11, 2004 | 09:53 AM
DaRKCrow's Avatar
Phil, you are just a power whore! Lets go for a spin out contest at the track this year again........
I lost my lip at LAGUNA in FEB so I was the winner, lets see whos gonna take a win this time ^ ^ d
DaRKCrow
Old Jun 11, 2004 | 09:55 AM
Elistan's Avatar
What are you using to modify redline? Emanage?
Old Jun 11, 2004 | 10:13 AM
TunedS2000's Avatar
How reliable is supercharging?
Old Jun 11, 2004 | 12:01 PM
vtecvoodoo's Avatar
Impressive, Phil
Old Jun 11, 2004 | 12:16 PM
TepEvan's Avatar
What about going to a single outlet exhaust? (unless you're keeping the dual for asthetics like me)
Old Jun 11, 2004 | 12:55 PM
mxt_77's Avatar
[QUOTE]Originally posted by Sideways
