More Differential Bad News...
Old Jul 17, 2001 | 01:11 PM
Wesmaster's Avatar
Default More Differential Bad News...
My dealership called me today after recieving all of the differential parts that I ordered (Kaaz LSD, Honda housing w/ comptech bearing caps). Evidently every other piece of the differential has to be replaced as well. They were not sure if these would come as part of the Kaaz/Housing or not.
He estimated the cost of these parts being $1,600! I'm going to have to sell the supercharger just to fix the damage that it caused (not really, but just about). The list:
FLANGE, COMPANION___________40440
SHAFT ASSY., OUTPUT___________40443
SCREW, ADJUST________________41131
PLATE, LOCK__________________42141
CASE, DIFFERENTIAL____________41170
GEAR SET, FINAL_______________41220
PIECE, DISTANCE_______________41271
SHIM SET_____________________41360
SPACER______________________41461
BREATHER ASSY._______________41935
BOLT________________________90001 QTY-2
BOLT________________________90002 QTY-10
BOLT________________________90003 QTY-1
BOLT________________________90004 QTY-1
BOLT________________________90005 QTY-8
BOLT________________________90006 QTY-4
BOLT, STUD___________________90011 QTY-4
PLUG, MAGNET_________________90081
PLUG________________________90082
NUT, LOCK____________________90201
GASKET______________________90401
GASKET______________________90402
WASHER, PINION_______________90403
CIRCLIP______________________90601 QTY-2
BEARING ASSY._________________91001
BEARING ASSY._________________91002
BEARING ASSY._________________91003 QTY-2
OIL SEAL______________________91201
OIL SEAL______________________91202
Is there any good news? I might end up upgrading my final gear while I'm replacing it
This totally sucks, I'm totally pissed.
Wesmaster
Old Jul 17, 2001 | 01:15 PM
Phantom's Avatar
So you can't install the parts left over from your last diff. because they are broken...or do you just have to use new parts just because?
Old Jul 17, 2001 | 01:17 PM
JBoggs's Avatar
$1600!!!! i hope this one lasts
Old Jul 17, 2001 | 01:26 PM
Wesmaster's Avatar
That's $1,600 + $850 (Kaaz LSD) + $880 (Housing + Bearing Caps) + $350 (Axle). You do the math, this sucks so bad.
Wesmaster
Old Jul 17, 2001 | 01:27 PM
moyopoyo's Avatar
sorry to hear about that Wes...if you did have to sell the supercharger, how much do you think you could get for it?
Old Jul 17, 2001 | 01:48 PM
Wesmaster's Avatar
Just got a quote from Trevor from http://www.HandAaccessories.com for just under $1,200. Time to research final gears.
Old Jul 17, 2001 | 01:50 PM
UCrazyKid's Avatar
It looks like there is another Diff case added in the parts list from the dealer so subtract that out. Since you are given the chance you should probably change you final gears. Aftermarket may even cost a little less than the Honda gears. You may be better off looking for a wrecked S2000. Buying the rearend and swaping in your new diff, etc.
andy
Old Jul 17, 2001 | 01:56 PM
Silver S2K's Avatar
Just to give you a little perspective, if you ding the left bank cat-converter on a M5 on an improperly installed water service cover, it'll set you back $3,300 I'd much rather have a super strong diff for that kind of money
Old Jul 17, 2001 | 02:03 PM
Wesmaster's Avatar
Turns out it's the "back" part of the casing (dealerships words).
Wesmaster
vtecvoodoo's Avatar
ouch
