Passenger Airbag
Old Dec 12, 2000 | 02:13 PM
Craig's Avatar
Does anybody know if there is any way to de-activate the passenger side airbag. I have a young son that loves to ride shotgun.
Old Dec 12, 2000 | 03:43 PM
SkipX's Avatar
You need to go to your dealer or http://www.nhtsa.dot.gov/airbags/ to obtain a form that you must submit in writing to nhtsa as per instuctions. Once you receive a response in writing, take that form back to your dealer.Then, and only then can they modify the SRS of your car. I was quoted $579.00 for the switch.
Old Dec 12, 2000 | 04:16 PM
spike's Avatar
search airbag options , should cost around 300, no more
Old Dec 12, 2000 | 04:19 PM
wanabe's Avatar
also seems to depend on state law. our dealers cant install the switch (or at least they wont install the switch)- they refer us to a body shop!
Old Dec 12, 2000 | 05:02 PM
Rush2000's Avatar
Couldn't you just set it off somehow and then replace the cover or remove a fuse?
Old Dec 12, 2000 | 05:58 PM
Scot's Avatar
i have an airbag switch in my S2000... cost was $275 from a place called Sensible Solutions, which I found on that NHTSA web site.... they even drove to my house to install it.... it is a little box that i had tucked under where the glovebox should be with a little key and some on-off lights.... very simple...
You fill out a form that basically says why you need the switch.... no dealer would even address the issue, and no installer wil charge more than about $300.
hope that helps.... if you are near DC, Sensible Solutions seems to be the answer..
Scot
Mar 27, 2002 10:25 AM
ALS2000
Jun 26, 2001 05:32 AM
Weasel
Jan 18, 2001 05:42 AM
tintboy
Nov 23, 2000 05:01 AM
doadea
Nov 9, 2000 08:29 PM
