Replacing differential mount
Old Oct 19, 2004 | 07:05 AM
geminigsr's Avatar
Default Replacing differential mount
Well, one of my diff mounts is gone.. For some reason when I got the diff replaced by Honda they decided not to cover that under warranty (shrug) - so I was looking at another 400 bux or so including labor/parts to fix it and a few more days wait for my car..
I decided to drive on it..
But it's getting bad now and I don't want to risk the diff going bad... so I might jsut take it to honda but before I do I'm curious if anybody has ever done this before and could provide a walkthrough and how hard it mightbe?
I'd rather pay the 100 and some change for the mount and do it myself
Old Oct 19, 2004 | 07:27 AM
xviper's Avatar
Once you get under there, you'll see how rediculously easy it is to change those out. You must have a means to support the diff in the position found since you are going to remove one of its attachment points (a second jack or a bunch of lumber).
There should only be one nut and two bolts to undo to get the mount free. Undo the end nut from the shaft that goes to the bracket that hold the side of the diff in place. Then remove the two bolts that hold the mount to the frame. You should then be able to slide the mount straight back from the bracket shaft.
BTW, nut = 47 lb/ft; bolts = 33 lb/ft.
Old Oct 19, 2004 | 07:54 AM
Sideways's Avatar
To help visualize, it is the red colored bolts:
A very simple proceedure, looks like another dealer attempted rip off.
Old Oct 19, 2004 | 08:05 AM
Stratocaster's Avatar
I actually have a rear sub frame in my garage. If you are interested, PM me an offer and I will pull them off.
Old Oct 19, 2004 | 03:05 PM
S2KANDRE's Avatar
last three posts....
Old Oct 19, 2004 | 07:52 PM
David1's Avatar
My mount went bad at about 4k miles. Easy to do. They even did it on the alighnment rack. Took about 30 minutes. The tech took off the sway bar (mount and joint) then removed the bolts. Piece of cake to do.
Old Oct 20, 2004 | 03:47 AM
CoralDoc's Avatar
As others have mentioned, the replacement is pretty straightforward. I'd contact Stratocaster and take him up on his helpful offer and at least save some money on the part(s).
What was the reason for the dealer not replacing it under warrantee?
nadeem
Jul 9, 2014 09:18 PM
IanGrimmy
Dec 20, 2011 09:29 AM
Envied
May 5, 2011 03:01 PM
