Escort 8500 X50 Direct Wire Smart Cord
Old Feb 22, 2005 | 11:54 AM
bs-inc.s2k's Avatar
Default Escort 8500 X50 Direct Wire Smart Cord
Any of you guys have this setup? If so where did you spice the wire? I went under where the fuse box was and i couldn't find anything to splice to...
-Lucky-
Old Feb 22, 2005 | 12:45 PM
124Spider's Avatar
Yeah, I installed this, but I don't know what you mean by "splice." There is a DIY thread on installing the hard wire kit for this detector, complete with good photos, which shows exactly where to get power. The only trick is to fish the cord which hooks up to the detector up the A-pillar; the other end of the cord--the one which has the "turn off sound" button--stays under the dash, and I just velcro'd it to the under side of the dash, to the left of the steering wheel.
Does this help?
Old Feb 22, 2005 | 01:43 PM
bs-inc.s2k's Avatar
i just did the install, i put it in with a female plug to the aux output thanks guys
Old Feb 23, 2005 | 08:11 AM
ruexp67's Avatar
That was going to be my reccomendation too.
Where did you mount the remote display?
I did this:
Old Feb 23, 2005 | 12:21 PM
TriaXenginE's Avatar
aux output? which aux output?
Old Feb 23, 2005 | 12:42 PM
124Spider's Avatar
I did this:
That's a very, very nice install. However, I would caution 2002-2005 owners, whose back windows are small, that mounting the detector where you have may unhealtily attenuate any signal from behind the car, since there is not a clean line of sight for us when the detector is so high.
I've mounted my detector just below the rear view mirror; not an ideal location from the visibility standpoint, but I believe that it makes it more effective.
Old Feb 24, 2005 | 08:41 AM
ruexp67's Avatar
I never thought about the rear window causing a problem. Honestly I almost never drive with the top up.
To the question above. There is a fuse panel on the driver's side under the dash. There are three extra spades available on it. One is always on, one is on with the lights and one is on with the ignition.
(I have an auxiliary outlet on all the time, and my windscreen is on with the lights. There is more info in my sig if you are interested.)
I have the radar detector on with ignition.
Old Feb 25, 2005 | 04:20 PM
PJK3's Avatar
i can assure you, that the softtop will not interfere any with radar signals. laser? probably, but radar? definitely not.
Old Feb 25, 2005 | 05:47 PM
Willie Gee's Avatar
The only other thing i would advise on doing is to mount the detector on the left side of the rearview. NFR told me to do this, and at first i hesitated. now i'm glad i did. it's way easier to see and the volume knob is easier to get to.
Old Feb 28, 2005 | 12:12 AM
bs-inc.s2k's Avatar
i mounted mine right under the rear view, and mounted the the mute button right above the steering column.
