2004-2009 existing slave cylinder mod
Old Mar 12, 2005 | 06:43 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Default 2004-2009 existing slave cylinder mod
I just did a delay valve removal to an existing 04 slave cylinder.....anybody do this yet? It's easy, $0.00
Scroll down a little for pic and details...
Old Mar 12, 2005 | 07:15 AM
xviper's Avatar
Billman, here is a similar thread:
https://www.s2ki.com/forums/index.php?showtopic=270439
This involved swapping an older cylinder onto a newer car. Please have a look and add any comments you can think of.
If you would like to do a thread up for your "How To", go ahead and I'll add it to the FAQs.
Old Mar 12, 2005 | 07:20 AM
Slows2k's Avatar
Billman may be talking about removing the Delay mechanism from the 04 slave cylinder.
Old Mar 12, 2005 | 07:43 AM
Billman250's Avatar
Top Answer: 1
Correct, Slows2k.....Here it is.....simply remove the shown parts, noting their order....
1 dust boot
2 Snap ring
3 hyd block off plug
4 delay valve screen and spring
5 delay bleed off valve
6 04-09 slave cylinder
-Remove boot 1
-Remove snap ring 2, you will need a very sharp pick to remove the snap ring.
-remove plug 3 with pliers.
-Using a small round punch, insert it in the hole where the brake hose bolt goes, and push out 4 and 5. Sometimes 4 and 5 will come out in one piece, make sure they both come out.
***ELIMINATE 4 and 5***
Re-assemble, bleed with new brake fluid, drive
I have added the pick I used in the process, note the angle. It will make the snap ring removal very easy.
Old Mar 12, 2005 | 07:50 AM
xviper's Avatar
Originally Posted by billman250,Mar 12 2005, 09:43 AM
Correct, Slows2k.....this is to remove the delay valve from the existing 04 slave cylinder....So you guys want the lowdown or what?
Well ..................... YEAH!
Put it in "Technical", please.
Old Mar 12, 2005 | 07:53 AM
Billman250's Avatar
Top Answer: 1
Sorry Xv, I was quick to edit...please move to Tech....
Old Mar 12, 2005 | 08:14 AM
Billman250's Avatar
Top Answer: 1
Anybody have a very late 03 model? You may have the delayed valve....if the slave cyl is black (cast iron), it is the old style with no delay valve.
If it's silver (aluminum), it is the new style with the delay valve....
Old Mar 12, 2005 | 08:21 AM
xviper's Avatar
Thanks, Billman. Moving to Technical and adding to FAQs.
Old Mar 13, 2005 | 02:36 AM
jlucas's Avatar
Thank you! I'm glad someone finally tried it!
Old Mar 17, 2005 | 02:33 PM
SIIK2NR's Avatar
Is it really that easy or should I just buy the cylinder without the delay?
