Evaporator Code (again)
Old Sep 13, 2001 | 04:04 PM
bbsilver's Avatar
Default Evaporator Code (again)
What would the probable symptoms of an evaporator code be? I had a purge valve replaced previously because of the code. They are doing a leak check tomorrow morning when it is cold.
Old Sep 13, 2001 | 04:54 PM
Utah S2K's Avatar
[QUOTE]Originally posted by bbsilver
[B]What would the probable symptoms of an evaporator code be?
Old Sep 13, 2001 | 05:04 PM
Utah S2K's Avatar
Most likely a DTC 4....Problem with the evaporator temperature sensor sircuit. May be no symptoms but there are several short to ground paths which may trigger this code.
Utah
Old Sep 13, 2001 | 05:11 PM
bbsilver's Avatar
Utah
I know, I'm kind of in the dark on this one. I have received no information other than that from the service manager. Like I said, this is the third time I have received this code. I'll get more info tomorrow evening after the 5 hour vacuum test.
Old Sep 13, 2001 | 05:26 PM
Utah S2K's Avatar
Third trip? Please get me all the info you can from the dealer.....including whether they reset the ECU each time:
https://www.s2ki.com/faqs/showfaq.php?threadid=17414
Old Sep 13, 2001 | 05:27 PM
Utah S2K's Avatar
Also what where the symptoms if any? AC no longer cooling car (based on leak down test)?
Old Sep 13, 2001 | 05:43 PM
bbsilver's Avatar
The first symptoms were erratic idling, sporadic stalls, and sluggish performance. The A/C has always worked as advertised. They replaced the purge valve and the problem went away with an ECU reset.
The second time they treated me like a moron saying I left my gas cap loose. That was BS; I checked. They wouldn't do the leak check until I had the light again. Don't know if they reset the ECU this time.
Third time...still waiting.
Old Sep 14, 2001 | 02:49 PM
Utah S2K's Avatar
As there is really no such thing as an "evaporator code" but several related to that system please ask you dealer to provide the code and how it was obtained (i.e. OBD-II serial port or Honda Scan Tool).
Utah
Old Sep 14, 2001 | 06:08 PM
bbsilver's Avatar
Well they did a leak check and nothing. Scratching their heads, they started pulling parts. She had a spider inside her. Don't know how it got in there, but it was the source. Weird. They were supposed to charge me, but didn't. Very nice of them.
9000 RPM Marc
May 24, 2008 09:49 AM
ChefJ
Jan 5, 2008 06:07 PM
Palmateer
Mar 27, 2002 03:43 PM
vtecvoodoo
Mar 3, 2002 02:08 PM
AusS2000
Jan 5, 2002 03:14 PM
