Comptech S/C and Spark Plugs
Old May 18, 2005 | 02:47 PM
jdmdohcpower's Avatar
Default Comptech S/C and Spark Plugs
I have the Copmtech kit and using stock plugs. I have the NGK V Power 10's but I gaped them to the same as the stock plugs and it ran like crap, so there out.
1. Will they work or should I get different ones?
2. what should the be gaped to?
3. What should the plugs be torqued to?
Thanks
Old May 18, 2005 | 03:06 PM
Black Nugget's Avatar
I am personally using the NGK Coppers (Part Number 7173) gapped at .035". Everything is so far so good
Torque them down to 222in/lbs, or better known as 18.5ft/lbs
Old May 18, 2005 | 03:07 PM
anyone use the v power's??
Old May 18, 2005 | 06:05 PM
xviper's Avatar
I believe NGK 7173 are "V-power" plugs. I just don't know what "10s" are.
This may have been one of the main problems. You need a smaller gap for F.I.
Old May 18, 2005 | 07:56 PM
Thanks for the info guys!!
Old May 18, 2005 | 08:24 PM
Slows2k's Avatar
A 10 heat range is 3 steps colder than a stock plug. They would not be the reccomended plug for this application. Go pick up some NGK 7173's, which are 1 range colder at 8.
Old May 18, 2005 | 10:11 PM
nsxinsac's Avatar
What would you gap them at, .035"? And is this the spark plug you recommend for supercharger application and daily driver:
NGK link
I'm also curious, I need to get new plugs asap.
Thanks
Old May 18, 2005 | 10:21 PM
PWRMKR's Avatar
From the searches I have performed here and questions to others, I got some Denso IK-24s. Some have reported disintegration issues with these plugs. So, I have concerns about recommending them to anyone running FI.
I also understand that you must stay far away from the platinum plugs. Copper and Iridium are the only viable options. Whatever plug you choose, with a minimum boost application, get the one step cooler then stock and gap to ~ .035"
Old May 18, 2005 | 10:35 PM
PWRMKR's Avatar
Originally Posted by nsxinsac,May 18 2005, 10:11 PM
Sparkplugs.com has a better price on those. $2.24 each.
Old May 19, 2005 | 02:10 AM
nsxinsac's Avatar
^ Thanks for the site. It does not list that spark plug for a S2000. If there a lot of members using that plug (NGK 7173)? Just want to find the best plug for SC that is daily driven.
Thanks
Sparkplugs.com link for S2000 applications
