Valentine One install help...
Old Dec 25, 2000 | 07:07 PM
devi0us's Avatar
I know most of this has been covered, and I don't want to get into any V1 vs. others religious debate...
I just got all the wiring concealed for my V1, except for making the power connections to the fusebox. Where have other people connected the positive lead to (in detail)? I'm trying to avoid digging around with a volt meter to find something that's hot while the ignition is on. Any pictures would be especially helpfull.
-Bill
Old Dec 25, 2000 | 07:16 PM
cdelena's Avatar
There are three empty fuse box connectors. The top one is hot with the lights, the second one is hot all the time, and the bottom one with the ignition.
Old Dec 25, 2000 | 07:27 PM
devi0us's Avatar
How does one wire to these? I was planning on tapping into a harness in the rear of the fuse box, is there an easier way?
[This message has been edited by devi0us (edited December 25, 2000).]
Old Dec 25, 2000 | 08:35 PM
cdelena's Avatar
Go to radio shack and buy a connector that slips over the blade in the fuse box. Much better than cutting into wires.
Old Dec 26, 2000 | 06:48 AM
Zippy's Avatar
Chris,
Thanks, this is a great help.
deviOus,
Nice opening.
Old Dec 26, 2000 | 08:08 AM
josh3io's Avatar
i dug thru the helm manual when i did mine to pick an appropriate wire. i used the inline wire splicer that came with the V1 to clip onto a big fat yellow wire under the dash.
Old Dec 26, 2000 | 11:20 PM
Digitool's Avatar
I used the wire clip that came w/the V1 and hooked it to the "power outlet" hot wire off of the fuse box, then a ground to where ever convenient.
I mounted the V1 w/the suction cup mount just under the rear-view-mirror. It gets a good look out the back and it makes it tough (er) to see from behind. =)
Ran a new cord up along the window frame and down the driver a-pillar to the fuse box, pretty clean and the clip tucks away nice w/the passenger visor when not in use.
Old Jan 1, 2001 | 11:10 AM
loki's Avatar
anyone have a part number for the radio shack fuse adaptor?
cheers,
-loki
Old Jan 2, 2001 | 07:32 AM
captainnice's Avatar
Where is the best place to buy a Valentine and how much are they?
Old Jan 2, 2001 | 07:39 AM
Schatten's Avatar
only one place to buy the V1 - http://www.valentine1.com and its $399.00 + any other little options you want to add onto it like the remote display.
