Valentine One install help...
I know most of this has been covered, and I don't want to get into any V1 vs. others religious debate...
I just got all the wiring concealed for my V1, except for making the power connections to the fusebox. Where have other people connected the positive lead to (in detail)? I'm trying to avoid digging around with a volt meter to find something that's hot while the ignition is on. Any pictures would be especially helpfull.
-Bill
-Bill
How does one wire to these? I was planning on tapping into a harness in the rear of the fuse box, is there an easier way?
[This message has been edited by devi0us (edited December 25, 2000).]
I used the wire clip that came w/the V1 and hooked it to the "power outlet" hot wire off of the fuse box, then a ground to where ever convenient.
I mounted the V1 w/the suction cup mount just under the rear-view-mirror. It gets a good look out the back and it makes it tough (er) to see from behind. =)
Ran a new cord up along the window frame and down the driver a-pillar to the fuse box, pretty clean and the clip tucks away nice w/the passenger visor when not in use.
only one place to buy the V1 - http://www.valentine1.com and its $399.00 + any other little options you want to add onto it like the remote display.
