Exhaust Weights
Ok, I installed my JIC Stainless Cat-back yesterday and decided I'd weigh everything including stock pieces. I haven't seen a thread here with multiple different exhaust weights. Perhaps others who have weighed their exhausts can post in here as well, I'll make a list and perhaps we can sticky this in one of the forums.
Cat Back
Stock.........................................50lb s
Amuse Dual Titan w/Res...............13.7lbs
Amuse Dual R1............................15lbs
Amuse R1000 (header back)..........9lbs
Apexi N1.....................................20.8lbs
ASM SS 70mm..............................21lbs
Borla...........................................49 lbs
Fujitsubo Legalis R.......................42.5lbs
Invidia Dual 60mm........................27lbs
JIC SS........................................16lbs
J's 70mm Ti (header back)............10lbs
J's 60RS......................................9.5lbs
Mugen.........................................24.5 lbs
Spoon N1.....................................19lbs
Spugen Single Ti............................17.5lbs
Supersprint...................................37lb s
T1R 63mm....................................25lbs
T1R 60RT......................................8lbs
T1R 70mmV1..................................22lbs
T1R 70RT........................................9lbs
T1R Sparrow..................................30lbs
T1R 70R Sparrow...........................35lbs
Toda Dual.....................................24.5lbs
Top Secret Full Ti............................5lbs
Veilside Teardrop...........................5.3lbs
Header
Stock..........................................25l bs (with heatshields)
Amuse...................................10lbs
Fujitsubo................................15lbs
J's Racing without wrap...........10lbs
OBX.......................................11.2lbs
Ricks 6-Plus.............................12.3lbs
Toda........................................12lbs
Catalytic Converter / Testpipe
Stock Cat................................12lbs
Custom Steel Testpipe.............4lbs
T1R 70mm Testpipe..................4lbs
Flywheels
Stock.....................................14.2lbs
Comptech...............................9lbs
Competition............................8.8lbs
Cat Back
Header
Flywheels
Hey guys...I'd really like to make a thread and have it linked so everybody could see what kind of weight savings they are getting before they even buy the exhaust. Help me out, for example:
Amuse R1 single
Amuse R1 Dual
Amuse R1000
Fujitsobo
Mugen
Spoon
T1R 63mm (exhaust only)
T1R 70mm (exhaust only)
J's 63RR
J's 70RR
Comptech
etc
Headers
J's (with and without wrap)
Amuse
Mugen
Comptech
If we can make one thread be the database it would make searching much easier...or at least we'd only have to link to one thread.
Amuse R1 single
Amuse R1 Dual
Amuse R1000
Fujitsobo
Mugen
Spoon
J's 63RR
J's 70RR
Comptech
etc
Headers
Amuse
Mugen
Comptech
I'm curious as to how much the header heat shield weighs. If it's significant it might be worth it to go with the wrap. I think it'd be smart to change the wrapping every once in awhile though, people often talk about moisture settling under it and ruining the header. Also, how much does the CAT heat shield weigh, and can you use the stock heat shield on any of the test pipes to make it look like a legal cat?
Heat Shield for cat is probably on 2-3lbs, and yes you can get it welded to a test pipe to make it look like a cat.
Thanks silver, I may try and take it to a shop to get some sort of flanges or tabs welded on so that I can bolt the shields on. I think the 2-3 pounds would be worth it to have a stock looking cat
I should be getting my T1R 70mm next week. I'll weigh and let you know how much for the catback part.
Thanks...yes let me know both the cat-back portion and the test pipe...but tell me seperately. Hopefully we can different test-pipe weights as well. Although they should all be close to the same.
. I just want to know how much the HKS Hi-Power weighs so that way I know how much weight savings from the stock exhaust it offers.
