Latch rattle?
Old Nov 1, 2005 | 06:15 AM
iammike's Avatar
Default Latch rattle?
I've got an '01 with 38000 miles... I bought it this summer so I've primarily had the top down so I may have missed this noise all along, but now that it has gotten cold and the top is up, I can't stand it. Whenever I hit a bump that causes the chassis to flex a little bit (might have nothing to do with flex), the driver's side roof latch makes a "clackity clack." Really annoying. Is there anything to tighten on them? Should I get a new latch? Is this a common problem? It could just be a product of it getting cold and things shrinking I suppose, but I doubt Honda would have sold a car that made this noise from the factory so I'm guessing something has worn out.
Old Nov 1, 2005 | 07:50 AM
zangiefisgod's Avatar
Go to hardtopguy.com and buy the hardtop strikers. They hold the top against the windshield tighter resulting in less rattle and wind noise. ~$50 bucks.
Old Nov 1, 2005 | 08:51 AM
iammike's Avatar
ordered! thanks! if this works i owe you a beer or something
Old Oct 2, 2006 | 11:24 AM
Sarek's Avatar
I also have this problem, did the hartop guy item fix it? I'm interested in getting one.
How did it work? or
Old Oct 2, 2006 | 08:29 PM
WarrenW's Avatar
Well, I have another issue.
I had my strikers replaced under warranty w/ the TSB. That was a few years ago. Now the car is out of waranty and I have the freakin' wind noise again.
So now what, do I get new hard top strikers or just live w/ it?
Warren
Old Oct 2, 2006 | 10:38 PM
Random1's Avatar
I recently had a rattle on my passenger side latch and the button bound when pushing it in once in a while. What I found was that one screw was missing and one was loose. If you open the latch and look behind it you will find the two small screws. I happened to have a screw and washer that fit. Once the two screws were tight the rattle went away and the button pushed in normally, no binding. I also found the two screws slightly loose on the driver side latch. These are small screws, so don't over tighten them.
I don't know if this is your problem, good luck.
Old Oct 3, 2006 | 05:36 AM
5SAY307's Avatar
I had that noise from the side latch too. I had it fixed by inserting a 1/2 inch square black felt tape or double side tape in the cavity where the alignment pin sets. Open your top and look at the striker, you should see a square cavity, just place the tape inside that cavity and it filled up the gap. No more metal to metal noise. Don't have to replace the Striker. I had over 40k miles and never had to replace the Striker. with the tape it never wear. I try grease, it won't work.
Good luck!!!
I know that noise drives me crazy.
Old Oct 3, 2006 | 09:26 AM
Sarek's Avatar
thanks guys, will try the tape and check the screws.
Old Oct 6, 2006 | 08:58 AM
530s2k's Avatar
Try putting some good grease on the seal.
Keatre
May 7, 2009 07:25 PM
01S2Kevin
Jan 4, 2008 12:48 PM
DallasClassic
Jun 9, 2005 08:52 AM
anthonys2k
Dec 19, 2004 06:28 AM
NVMY4N
Mar 1, 2004 11:44 AM
