amsoil...
Old Jan 19, 2006 | 01:53 PM
riceburners2001's Avatar
Thumbs up amsoil...
so.. i wanna change my trans + diff oil soon.. and i want to use amsoil....so which one???
trans = 75w-90 API GL-4 or dyn manual synchromech TMF(5w-30)<---
diff = severe gear EP 75w-90?
Old Jan 19, 2006 | 04:34 PM
anyone???
Old Jan 19, 2006 | 07:44 PM
vtec9's Avatar
You want a GL-5 transmission fluid. I imagine the most recommended would be Honda MTF, or GM synchromesh friction modified (what I am running).
Old Jan 19, 2006 | 08:13 PM
SojuSoulja's Avatar
I recently switched to amsoiil diff and tranny fluid. Great stuff. My tranny is a lot smoother.
I used Sever Gear 75w-90 for the diff and Manual Transmission Syncromesh Fluid.
These were the ones recommended on their site. They have a pretty good product appliaction guide. You should check it out.
https://www.amsoil.com/scripts/runis...msoiloaf:index
Old Jan 19, 2006 | 08:22 PM
i am using amsoil 0w-30 engine oil and i love it... have u used the GM synchromesh friction modified? which is better??? i am going to get the diff oil from amsoil...should i also get the manual synchromech TMF? or the GM synchromesh friction modified??
Old Jan 19, 2006 | 08:41 PM
SojuSoulja's Avatar
I havn't used any other Tranny fluid. However...my car was making chatter noises but after using the amsoil tranny fluid the chatter went away.
I've been using their oil and filter for a long time now on my other cars. I trust their stuff.
Old Jan 19, 2006 | 08:43 PM
S2kracka's Avatar
Use GL-4 in the tranny, NOT GL-5 like recomended above! People really need to keep their mouths shut unless they actually know what they are talking about. This is happeneing far too frequently on this board lately. Also, do not use a regular motor oil in your transmissions, there are much better things with the proper additives available. Honda MTF is always a good standby, supposedly GMSMFM is a good alternative but I'm not sure if it'll provide the protection we need for long-term use, and Redline MTL is very similar to the Honda MTF except it has a better additive package and is fully synthetic basically meaning it will last longer and protect better (my personal choice).
You may use a 75W-90 GL-5 fluid in the diff, but a 90W GL-5 is what is recomended by Honda per the owner's manuals. LE-607 is by far the best rear differential fluid available to us at this time, it is a 90W GL-5 and readily available from certain S2k vendors for around $12/qt.
Old Jan 19, 2006 | 08:57 PM
i meant i currently use 0w-30 engine oil in my engine... i should have been more clear...hehe
S2kracka, how about the amsoil manual synchromech TMF compared to the redline???
Old Jan 19, 2006 | 09:11 PM
S2kracka's Avatar
I am not sure how the Amsoil compares to the Redline; both seem to make good products, but personally I am not a fan of Amsoil and have had great sucess with Redline products. I live about 10 miles away from the Amsoil headquarters and had a chance to work for them in the research dept. but I turned it down. Why? I don't want to work in Wisconsin
Why are you using 0W-30 in your engine? It would be better to go with a 10W-30 unless you live in the Arctic.
Old Jan 19, 2006 | 09:42 PM
hmmmm..... it was recomended to me...at amsoil's site.. its says its suppose to replace 10w-30 and 5w-30... could it hurt my engine??
