Engine problem---help please!
Old Nov 25, 2001 | 12:42 AM
HwangTKD's Avatar
Default Engine problem---help please!
Hey all,
Ok here is my problem. I noticed this problem twice in bumper to bumper traffic. When the car is rolling at 7 mph and the revs are at 1.5 - 2K it hesitates BADLY and starts to buck when I hit the gas. Is it the map sensor? Please give me some advice!
Thanks a bunch!
Bobby
Old Nov 25, 2001 | 12:44 AM
bayareas2k1's Avatar
[QUOTE]Originally posted by HwangTKD
[B]Hey all,
Old Nov 25, 2001 | 01:26 AM
Blk01S2k's Avatar
happens to me too.. to sensitive throttle response... i know exactly what your talking about though and if theres a fix i want it
Old Nov 25, 2001 | 03:54 AM
djohnston's Avatar
I don't mean to sound like an old fart at 37, but are you guys who are experiencing this problem new to cars with manual transmissions? Or are you new to driving period?
In my experience, ANY stick-shift car does not like to be under 2000 RPM unless it's idling. If you're in heavy traffic, and the tach starts to fall below two grand, push in the clutch. If you give the engine gas when it's below 2000 it will buck because that's the nature of the high-RPM beast.
Maybe it's different if you're driving a torque monster like a Corvette, but my knowledge comes from small displacement four-bangers only, anyone else have different experience?
Old Nov 25, 2001 | 07:36 AM
xviper's Avatar
[QUOTE]Originally posted by djohnston
[B]I don't mean to sound like an old fart at 37, but are you guys who are experiencing this problem new to cars with manual transmissions?
Old Nov 25, 2001 | 08:31 AM
lvs2k's Avatar
Another "old guy" here. The main problem is in your foot, not the map sensor. Push in the clutch, release slowly as you depress throttle; it works every time. I find this problem can be especially acute when driving slowly through a parking lot and going over one of those damn speed bumps.
Old Nov 25, 2001 | 08:48 AM
S2000 Owner's Avatar
Many times when caught in slow traffic, I let the car idle. In first gear on level ground it will do 4 mph @ 1000 rpm; in second it will do 7 mph, and in third it will do 9 mph.
However, if you wish to get going from this position, either slip the clutch and moderate the gas --- or put your foot to the floor; anywhere in between, there is not enough rpm to overcome the lack of torque, and it sounds and acts like the old "Indy" cars getting out of the pits during a test day.
Old Nov 25, 2001 | 08:58 AM
IS200's Avatar
Check out the thread below for more info on the "stumbling / stalling / bucking / hesitating / jerking / rodeo bull riding / makes-you-look-like-you-can't-drive-a-stick characteristic of the S2000
https://www.s2ki.com/forums/showthread.php?...ngine+vibration
Old Nov 25, 2001 | 11:51 AM
Col's Avatar
Col
HWangTKD,
Don't be put off by the comments, assuming you are not letting the idle drop too low I agree with you as I have experienced exactly the same problem. In addition I had a further problem where when I accelerated off in first it would start to miss just like hitting the rev limiter. This happened regularly for about two weeks then for some other reason has stopped and (touch wood) hasn't come back now for over 4 months.
Everyone here in Oz said exactly the same thing about me, except that I had my neighbour as witness and he felt the bucking and fully agred that it wasn't my driving.
When I took it to the service to get it looked at, would you believe they couldn't get it to occur then cleared the ECU without noting the readings even though they admitted that it had recorded some....
Bottom line, no answer what caused it but it has dissapeared on my car.
Old Nov 25, 2001 | 05:56 PM
Hiroprotaganist's Avatar
I am experiencing this problem also. This thread was pointed out to me after I started an additional one:
https://www.s2ki.com/forums/showthread.php?...&threadid=36366
If anyone is interesting in further contributing, I would love to have additional feedback.
Thanks!
wangdoom
Aug 5, 2005 01:23 PM
S2K TX
Nov 29, 2004 09:37 AM
phoenix9999
Dec 6, 2003 11:54 PM
mingster
Jun 5, 2002 06:01 PM
mas
Feb 12, 2002 07:18 AM
