high speed cruising
Old Feb 27, 2006 | 12:29 PM
dyhppy's Avatar
Default high speed cruising
i feel uncomfortable driving above 80 or so on the freeway for long periods of time. i know it's all in my head, but in many cars, i feel like it's wasting gas, it's noisier and less safe. so i end up around 70 in the middle lane, unless i feel like a spurt of speed. anyone else feel similar?
Old Feb 27, 2006 | 12:32 PM
Joe04sk's Avatar
I don't. All you need is a good radar detector. To me 80 is the perfect speed to cruise at.
Old Feb 27, 2006 | 12:33 PM
jasonw's Avatar
I try to do that. If the road is clear and you are doing 80, that's the best time for a cop to pull you over.
Old Feb 27, 2006 | 12:38 PM
530s2k's Avatar
80-85 here. The key is to find the guy going as fast or faster, set the cruise, and follow. 9/10 times the cop will pull them over first.
Old Feb 27, 2006 | 12:40 PM
mooshy_sushi's Avatar
same here. i try to find someone whos going faster than me, but not an insane speed, then follow. i hate being the leader on the road, i rather be the follower and allow someone else to set the pace. when its open road however and im the only one, i actually tend to slow it down.
Old Feb 27, 2006 | 12:47 PM
S2kracka's Avatar
I have found 80 yields better gas mileage than 70 in these cars. The F20C is definitely more efficient in the higher RPM's. My best mileage ever was driving a steady 85 mph.
Old Feb 27, 2006 | 12:49 PM
jasonw's Avatar
What MPG was that?
I've seen my MPG go up by about 3 by dropping from 80 to 70.
80-90% on the highway...
Old Feb 27, 2006 | 12:50 PM
dyhppy's Avatar
can anyone verify the mpg number? doesn't make sense.
Old Feb 27, 2006 | 01:06 PM
kfar09's Avatar
I dont cruise any lower then 80. Valentine 1 radar detector is your friend
Old Feb 27, 2006 | 01:08 PM
slimjim8201's Avatar
Must be some good crack you are smoking.
It takes a lot more energy to plow though the air at 80 mph than it does at 70 mph. Even if the engine is more volumetrically efficient at higher revs (I'm not sure that it is for this case), it wouldnt be enough to make up for the increased drag.
You will almost always get maximum fuel economy between 40-60 mph in top gear. This applies to all cars.
