Remote frequency
Old Mar 20, 2006 | 08:51 AM
kevkranker's Avatar
Default Remote frequency
It's been said over and over again that you can't use the accord key on the s2000. I had to see it to believe it. I got the key to work and start up the car. The problem is the accord remote uses a different frequency than the S. I can't get the remote to work...
I know that in remote controlled cars you can change the crystals and that swithes frequencys. Would this work with the keyless entry remotes? Could i solder the crystal from one fob to another?
I was wondering if any of you EJ's might have some ideas.
thanks
Old Mar 20, 2006 | 09:20 AM
MacGyver's Avatar
Those systems will typically use a SAW (Surface Acoustic Wave) Resonator, rather than a crystal, but the principle is still the same (may need to tweak the tuning caps). A new remote can be had for $20 on eBay, though, so I can't imagine why you would bother swapping SAWs, not to mention the equipment you need to check the frequency.
Old Mar 20, 2006 | 11:54 AM
kevkranker's Avatar
It would be cool to have the key and the remote all in one
Is there a place where i could get the frequency changed for price? I have already spend $85 so a little more would be so bad.
Thanks for the info!
PJD
Apr 23, 2013 11:37 AM
05BlueS2000
May 31, 2009 03:48 AM
daveeppy
May 30, 2008 08:52 AM
krikke_s2000
Oct 12, 2007 09:23 AM
jzz30
Feb 6, 2007 03:17 PM
