Vacuum line help? Quiz inside
Old Apr 25, 2006 | 07:34 PM
skibum's Avatar
Default Vacuum line help? Quiz inside
I borrowed this pic from a friend. Does anyone know where the indicated line goes (besides the intake manifold obviously). I took my turbo kit off and am having a problem locating where it plugs in to. Thank you so much, this is the only line between me starting her up.
Old Apr 25, 2006 | 08:03 PM
xviper's Avatar
That's the fuel return line. It attaches to the underside of the stock fuel pressure reg and goes to the metal hard line that goes back to the fuel tank. On a supercharger kit, this line goes from the underside of the stock FPR to the inlet of the S/C kit's fuel pressure reg.
Old Apr 25, 2006 | 08:07 PM
skibum's Avatar
It's a fuel return line that connects to the intake manifold? Do you have any closer pics of the routing?
Old Apr 25, 2006 | 08:32 PM
GoFaassttt's Avatar
It's not the fuel return line.
That line makes it's way to the driver's side of the manifold into the brass colored fitting that points downward and is just past the TB. However, underneath the manifold it is connected to either a metal line or a "t".
Old Apr 25, 2006 | 08:34 PM
Slows2k's Avatar
That's not the Fuel return line in your pic, It's the Evap purge line. It goes under the manifold to a metal pipe, then another hose attaches to the EVAP purge solenoid on the frame rail.
The Fuel return line goes from the bottom of the regulator under the manifold to a hardline on the inside if the framerail.
Old Apr 25, 2006 | 08:51 PM
skibum's Avatar
I do have a black metal (oddly shaped) t-pipe that I assume is what it connects to.
If one side of the T goes to the evap surge solenoid, where does the other one go?
Any diagrams would be super helpful.
Old Apr 25, 2006 | 08:55 PM
GoFaassttt's Avatar
It connects to the brass colored fitting (that points down) located next to the TB on the intake manifold.
Old Apr 26, 2006 | 04:23 AM
xviper's Avatar
I lose. Dyslexia set in.
Old Apr 26, 2006 | 07:25 AM
Wisconsin S2k's Avatar
must be that old age.
Old Apr 26, 2006 | 07:37 AM
Jasonoff's Avatar
Banned
Get those knuckles up on the table... i'm fetching the meterstick
