Permanent fix for the driver's window TSB? Need 2002 info...
Old Dec 11, 2001 | 01:53 AM
DJ Qube's Avatar
Default Permanent fix for the driver's window TSB? Need 2002 info...
My MY '01 driver's side window has the infamous problem of not going down all the way when lowering the top or doing the "one-touch" autodown button press (TSB-01008). I've put off getting it fixed because the replacement relay has also been failing in the past. Now that the '02 is out, I'm thinking Honda may have come up with a new relay or motor or whatever the replacement part is.
So, does anyone with the MY '02 have the problem yet? Can anyone get a hold of the part number for the driver's side motor / relay for the MY 00-01 and / or the MY02 to see if the part has been updated?
Old Dec 11, 2001 | 05:35 AM
firsts2k's Avatar
top!
Old Dec 11, 2001 | 07:23 AM
bkw's Avatar
bkw
you know what sucks?? right after reading this post, my drivers side window started doing this also!! ARGH!
hopefully my dealer wont give me a hard time cuz my windows are tinted!
and oh, the window goes down about 1" then stops.. then i have to press it again. is this the same with all of you?
Old Dec 11, 2001 | 07:32 AM
s2ktaxi's Avatar
I'm just going to live with it until a permanent fix is found.
Old Dec 13, 2001 | 04:51 PM
DJ Qube's Avatar
I just came from the dealer. The tech guy says there is an updated window relay. It's on order for me, and will get there monday, when I'll have it put in. I'll try and get a part number for the old and the new.
Old Dec 13, 2001 | 05:07 PM
jpotts's Avatar
mine has stopped working as well - look forward to the part number - thanks
Old Dec 13, 2001 | 07:58 PM
Red_s2k's Avatar
My dealer has a regulator/motor on order... should be in next week. Also have the updated clutch on order. I also hope to get the updated latches for the top. Was presently surprised with how easy it was to get them to replace the clutch.
Old Dec 13, 2001 | 08:20 PM
amartin's Avatar
Well..if u think about it...if this is all u have to bitch about...your car seriously rocks :-)
Happy Holidays,
-- Aaron
Old Dec 14, 2001 | 12:29 AM
DJ Qube's Avatar
Happy Holidays,
-- Aaron
I'm doing the clutch, too. Notchy first gear, buzzing 4k rpm, etc.
passenger side weatherstripping for the top drenches the passenger after a rain.
Old Dec 14, 2001 | 03:06 AM
s2ktaxi's Avatar
Given the way the TSB was worded and the fact that they get paid by American Honda - just as though it were you paying it (ok maybe at a slightly discounted rate for labor), it is still work and money for them.
