KW Variant 3 Settings?
Old May 3, 2006 | 05:58 PM
IIGQ4U's Avatar
Default KW Variant 3 Settings?
Hi everybody
I just ordered a set of KW Variant 3 coilovers and was wondering what you believe is a good setup for what will be a majority of street driving and occasional track?
I just want a setup to potentially neutralize the rear end... Post your setups here!
Old May 3, 2006 | 08:45 PM
Kobe's Avatar
why don't you have a different setup for the street and track? though to be honest the bump setting is a bit of a pain to change..
For the road..I use
bump 1.5 all round
rebound 1.5 front
rear 2.5 rear
KW recommended to me for track use:
bump 0.75 all round
rebound 0.75 front
rebound 1.5 rear
this was great for dry/high speed corners..crests/compressions.. but not OK for the wet and or flat slow corners where the car would understeer considerably despite 215 front tyres.
Old May 4, 2006 | 02:35 AM
Young_R's Avatar
^good info.
Old May 4, 2006 | 05:40 AM
IIGQ4U's Avatar
So Kobe... You have the rear end setup softer than the front right?
Old May 4, 2006 | 08:43 AM
Kobe's Avatar
yes the rebound is softer in the rear..
by the way, I guess your alignment settings and tyre choice will interact with this - so copy/paste wouldn't necessarily work out.
Old May 4, 2006 | 10:44 AM
pointa-b-c's Avatar
I'm a very lazy person, so track and street setups are the same.
IIRC.
bump 0.5 all round
rebound 0.5 front
rear 1.0 rear
Alignment spec:
front camber -1.75
rear camber -2.5
rear toe in 1/16
Tires:
F:235/40/17
R:255/40/17
ToyoRA1
I am pretty happy with this setup now, only thing I do adjust is rear rebound, depending on how tail happy the car is. Hope this help.
Old May 4, 2006 | 10:48 AM
IIGQ4U's Avatar
Great, keep the setups rolling folks!
My set just came in today =)
Kobe's Avatar
obviously you don't have speed bumps in your area
even with softer setting than yours.. it's painful going over these things..
Old May 4, 2006 | 10:53 AM
IIGQ4U's Avatar
I hate going over speed bumps stock!
Old May 4, 2006 | 10:59 AM
gfacter's Avatar
I need to find my notes, I usually base line the rebound and dial it in. to around .5 to 1 front and 1. 1.5 rear.
.75 on the bump
