Another oil question
Old May 14, 2006 | 04:44 PM
kellyvu's Avatar
Default Another oil question
Honda dealer filled my car with Quaker State synthetic oil. Is it OK to top off with Mobile 1 synthetic? I did a search on this and the results were a little ambiguous so I thought I'd just post the question. Thanks.
Old May 14, 2006 | 05:01 PM
tokyo_james's Avatar
Depends on your point of view. I would have thought that it would be fine to leave it as is, but I would think that most people will advise you to drain it and replace with a better quality. In terms of the cost of diong it, you are probably best doing the change IMHO.
Old May 14, 2006 | 05:02 PM
zdave87's Avatar
Member
man!!
You can't mix Quaker State synthetic oil with Mobile 1!! Totally different blends!
Old May 14, 2006 | 05:12 PM
Originally Posted by zdave87,May 15 2006, 09:02 AM
man!!
So what? Different blends aren't going to affect anything too much! What do you think it is going to do?
Old May 14, 2006 | 05:14 PM
zdave87's Avatar
Member
Too much you say???
Are you insane??
You are mixing two totally different chemical/liquid compounds!!
Old May 14, 2006 | 05:32 PM
darkfx's Avatar
It won't affect anything
Old May 14, 2006 | 05:35 PM
zdave87's Avatar
Member
Mobile 1 and Quaker State do not mix at all.
Old May 14, 2006 | 05:42 PM
xviper's Avatar
Not being a smartass, but why? The two oils should be of the same rating. As far as my experience goes, you can mix non-synthetic with synthetic; one brand with any other brand; even different viscosities, so long as the "rating" (SF, SG, SH, whatever) is the same.
Old May 14, 2006 | 05:49 PM
iamhomin's Avatar
Yes, as long as the oils are the same "ratings", the brand doesn't matter.
Old May 14, 2006 | 06:46 PM
Dopes6070's Avatar
Any oil is better then running low, thats how I look at it.
