sub box build angles... ?
Old Jun 21, 2006 | 03:54 PM
campbuds's Avatar
Default sub box build angles... ?
So what angles are used to build the box in the middle on this link?
http://www.geocities.com/mariobonifa...asurements.htm
Old Jun 21, 2006 | 06:38 PM
WLAURENT's Avatar
http://www.ddgps.com/textweb/UNIT%203%20Ge...%20GEOMETRY.htm
Old Jun 21, 2006 | 07:15 PM
NFRs2000NYC's Avatar
Originally Posted by WLAURENT,Jun 21 2006, 09:38 PM
You kill me sometimes William.....
:campbuds:
What angle are you having a problem with? Is it these pieces? \ / ?
Old Jun 22, 2006 | 05:33 AM
campbuds's Avatar
:campbuds:
Thanks for the geometry lesson!!
Yes I am referring to the \ /
What angles do i need the sides at to make it all line up all pretty.
Unfotunately in my accounting I have yet to use geometry.
Old Jun 22, 2006 | 06:05 AM
campbuds's Avatar
Wait what about this!
http://www.1728.com/quadtrap.htm
The only thing I see then is taking into account the thickness of the wood (3/4") when figuring the length of the sides.
So I still need some help here...
Old Jun 22, 2006 | 06:07 AM
WLAURENT's Avatar
Her you go:
http://www.webmath.com/rtri.html
With values entered.
http://www.webmath.com/cgi-bin/rtri.cgi?c=...e=&b=&d=%3F&a=3
You know the hypotenuse is 7.125 and side A is equal to (23 - 17)/2 (or 3")
This gives you an approximate angle of 65 degrees
Old Jun 22, 2006 | 11:46 AM
campbuds's Avatar
Has no one ever built this box before?
Old Jun 22, 2006 | 01:41 PM
campbuds's Avatar
the 7.125 sides.... wouldn't they become 8.625 with the 3/4 thickness of the wood?
Old Jun 22, 2006 | 08:33 PM
PJK3's Avatar
didn't i figure this one out a couple years ago?
regretfully, i never key worded it. i think i figured it out for ajira...
sure enough, i did.
http://forums.s2ki.com/forums/index.php?showtopic=185903
read up on that thread, it should help ya out. (i'm pretty sure it's the same enclosure... yup it is.)
Old Jun 23, 2006 | 07:35 AM
campbuds's Avatar
ok while that helped a bit, I am still struggling with the depth of the box. What is the actual hieght of the trapezoid on the sides of the box?
(not the length of it's sides but it's actual height?)
