Need help!Need to monitor AFR for Vortech S/C
Yo! Need your help guys.
I will be soon installing Vortech S/C on my S2K, Is it necessary to add in gauges to monitor AFR as well, i seems to have conflicting opinion in my UK forum site. Certainly my man with years of experiences installing S/C in varies makes and model including Mustang does not think so.
I am confused!! I intend to run S/C on stock engine and ECU...for the moment anyway
Thanks
Thanks
most of the Vortech SC runs leans at the the top of the RPM range.
I strongly recomend you a Wideband, so you will know if you are runing lean, I know some members in Europe who has blow their engine using a Vortech SC because they do not checked their A/F ratio.
I was running lean with the stock comptech SC, 5.5 psi.
every car has its tricks what is good for one does not menad it is good for other, so ask you this question how many S2000 SC has your man installed?
have a look here
www.plxdevices.com
have a look here
www.plxdevices.com
johev
Apr 21, 2002 02:28 PM
