So my car is dead!!!!!!
Old Feb 3, 2002 | 08:46 PM
Fed's Avatar
Fed
Default So my car is dead!!!!!!
Coming off the beltway today, my car started making a knocking sound. This sound occurs on idle as well as when the clutch is engaged. For some reason, on higher gears it dissipates, somewhat. Luckily, this started happening 3 block away from a Honda dealership. So right now, my baby is sitting at College Park Honda, by herself, waiting for a tech to take a look at her tomorrow. I on the other hand, have drunk heavily tonight, trying to drown away the suffering. It was so painfull hearing her suffer the extra three block to the dealership. I was thinking it was probably one of the teeth from the pressure plate that broke off, but that wouldn't be a problem when the car is idle. Now I'm thinking more of a cylinder failure, or a dreaded bent valve. However I did not downshift anywhere for this to happen. Any ideas on what it may be? I guess I will have to wait until tomorrow to find out. All this 3 days before she was scheduled to go in for service.
Old Feb 3, 2002 | 10:18 PM
Project Dream's Avatar
You didn't drive while you were intoxicated did you? Just wondering..
Old Feb 3, 2002 | 10:46 PM
Dinnyin's Avatar
have you been checking the oil everytime you stop for gas?
dinnyin
Old Feb 4, 2002 | 05:48 AM
Fed's Avatar
Fed
No,no, did not drive while intoxicated, been checking the oil, when the problem started happening, no oil leaks, oil filter was still on, and level was ok, also, did not get any cod from the ODB. Turned car off, and restarted and she started without a problem, however the knocking was still there.
Old Feb 4, 2002 | 07:14 AM
mstw's Avatar
could it be bad plugs or valve adjustment?
Old Feb 4, 2002 | 07:22 AM
Hiroprotaganist's Avatar
Maybe the plugs were loose?! That was happening with some other cars. I had mine checked out a few months back.
Sorry man - really.
Old Feb 4, 2002 | 07:27 AM
Fed's Avatar
Fed
I am hoping it is nothing majopr, however, I harepared myself for the worst. Right now, as long as it gets fixed I don't care. I'm just not in the mood to be given a hard time about it being covered under warranty.
I though about the loose spark plugs, however, the sound dissipated as I went through the higher gears, 4, 5 and 6.
Old Feb 4, 2002 | 08:50 AM
Fed's Avatar
Fed
Just got a call from the dealer, they called Honda, the problem is internal, the engine is being taken apart as we speak to diagnose the problem. Part of me doesn't want it anymore!!!
Old Feb 4, 2002 | 08:53 AM
mstw's Avatar
oh no! that sucks dude. I hope its nothing major. Well, if they replaced the broken parts with brand new parts, its like a whole new engine for you.
Hope everything works out fine at the best of your interest.
Old Feb 4, 2002 | 02:11 PM
RandyP's Avatar
On the plus side, many have had the engine replaced with no lingering problems. Given your description, it may be the 4th cylinder problem some '01 engines have had.
