Clear Up your Headlights
Old Feb 19, 2007 | 12:14 PM
HankookS2K's Avatar
Default Clear Up your Headlights
Well I just got my passenger side headlight replaced and it really looks out of place next to my other headlight which is foggy and hazy. I tried to apply plastic polish and cleaner and it didn't work. The haze was soo bad i had to go about the wetsanding and buffing. So here is a guide to clear those headlights up!
What I used:
- 1500 grit sandpaper
- 2000 grit sandpaper
- Dewalt DW849 Buffer
- Meguiars SOLO Buffing Compound (Any Buffing Compound will work though)
- Car Brite Phaze Glaze
- Car Brite Crystal Shine
- Wool and Foam pads
- Microfiber towels
- WATER
Procedure:
I think the best way to do this is to take off your bumper first so you dont sand your bumper or accidently burn it with the buffer. Here are some GREAT instructions to take it off How to Take off front Bumper
Here are some pictures of my headlight. It looks worse in person, but no compound put on by hand would get rid of the haze.
here is a picture of my new passenger side headlight, as you can see there is a big difference.
a good thing to do is to tape off around the headlight by the fender also. I started sanding the headlight with the 1500 to get rid of the haze. If its REALLY bad then go to 1200 grit, but no less than 1000. 1500 did perfect for me. USE LOTS OF WATER. Here is a pic of it done at 1500.
Then finish off with 2000 grit. U can stop at the 1500 grit but i went higher so my buffing time was reduced. Its easier to buff out 2000 grit then 1500 grit scratches. Here is 2000 grit.
Alright then i whipped out the buffer and the compounds. I use a Dewalt DW849. I don't like the porter cable. Ive always stuck with my dewalt. Also used Meguiars SOLO buffing compound and Car Brite's Phaze Glaze and Crystal Shine. Also I used 1 wool pad to cut and 2 foam pads to add glaze and polish. Here are the pics of everything.
Next I applied the buffing compound and buffed with the wool pad. Let the weight of the buffer do the work and dont press to hard or else you burn the plastic. Buff at speed between 2000 to 3000 rpm
Here is the pic after buffing the compound only. It looks a LOT better.
Then apply the glaze. I buffed with a coarse foam pad at 1500 rpm
Then apply cyrstal shine to add polish and shine. I buffed with a finishing foam pad at 1000 rpm
Then wipe clean with microfiber towel and add a plastic polish of your choice by hand. Here are my finished pics.
By the way you don't have to use all the polishes and glazes like i did. You can just get away with the buffing compound and then apply a plastic polish. Im just anal like that. Tell me what ya think! Hope this helps!
Old Feb 19, 2007 | 12:22 PM
wanabe's Avatar
nice job, and great post-
i especially like your pics and full report
we have another post on this...
https://www.s2ki.com/forums/index.php?showtopic=403076
should i merge these, or would you prefer to leave yours separate?
and btw, it shows that you have what it takes to be a wacko like the rest of us-
so if you want the official badge on your posts, just pm me and i will make it happen!
Old Feb 19, 2007 | 07:53 PM
Sarek's Avatar
Very Nice! I did similar with my Porter Cable and Menzerna (because I'm too scared to try a rotary).
Never thought of wetsanding the plastic though, looks awesome!
You've inspired me to try this on my wifes car. Her hazing is so bad that you can't even tell if the headlights are on because the street lights light the street better than her headlights do!
Thanks for the great write up!
Old Feb 19, 2007 | 08:53 PM
S2KAYYY's Avatar
Old Feb 19, 2007 | 10:15 PM
HankookS2K's Avatar
Thanks Sarek. Hope the write up helps ya with your wifes car! Post some pics if you do it!
Old Feb 19, 2007 | 10:48 PM
Apak25's Avatar
great write up and the results are awesome.
Old Feb 22, 2007 | 11:59 PM
guardiase's Avatar
Do your headlights reflect any kind of swirls under sunlight or halogen lighting or is it perfectly clear? I've been trying to completely remove any kind of swirl marks on my headlights, using 2500 grit sandpaper, doing 4-6 passes of rubbing compound with a PC on speed 6, but to no avail.
Old Mar 1, 2007 | 10:16 PM
HankookS2K's Avatar
its perfectly clear...no swirls of any sort...what kind of rubbing compound are you using? and also im not familiar with the PC but are you using it at a high speed? i did mine at 3000 rpm with a wool pad to ensure i was cutting through the plastic to remove the scratches.
Old Mar 1, 2007 | 10:36 PM
guardiase's Avatar
I was polishing with Sonus SFX-1 and the yellow SFX-1 pad. Speed 6 on the PC is 6000 OPM, which is probably around the 1000 RPM range on a rotary (really rough estimate). The SFX-1 polish and pad are middle-ground in terms of abrasiveness, so maybe that's why I'm not getting through it all. I will pick up a rotary in the near future and hopefully redo my headlights with the polish I have now, Poorboy's SSR2.5.
Old Mar 2, 2007 | 04:51 AM
HankookS2K's Avatar
yea if its roughly around the 1000rpm then its definately not fast enough to impact the plastic. I use 1000rpm when im polishing. if your in the market for a good buffer look at the DeWalt DW849. You can purchase those buffers on ebay for 160 shipped! A very nice deal considering at retail stores they vary from 300 to 400 dollars! I have done detailing for the last 3 years and everywhere that i have been uses the dw849. even Car Brite recommends a rotary buffer like the DW849 and im a firm believer in Car Brites products.
and also you wanna get a buffing compound for cutting. a good gritty compound should get the job done. If you need any further help with any compounds or detailing let me know!
