Help with dome door light switch
Old Sep 23, 2007 | 01:20 AM
S2000_FUN's Avatar
Default Help with dome door light switch
I just realized that my dome light isn't working when I open the driver
Old Sep 23, 2007 | 02:06 AM
S2Koupe's Avatar
clean off the connectors inside your map light.
https://www.s2ki.com/forums/index.php?showtopic=486545
take note on how the map light comes apart. pry the clear plastic off first.
Old Sep 23, 2007 | 02:23 AM
S2000_FUN's Avatar
Thank you for your reply and your feedback but the map light work's perfectly with the keyless entry and in the on position. It also works when i am oppening the passenger's side door so it cannot be that. Most possible is the drivers side door light switch but i do not know how to check it.
Old Sep 23, 2007 | 04:00 AM
shepp's Avatar
the door switches are usually very simple. they just complete the circuit to the negative earth.
Most probably a rusted/mucky contact,
remove the door switch and check that the fixing point is not rusty (if so clean it)
Check the door switch with a continuity meter, when pushed in there should be no continuity between the input and where the metal part of the switch touches the body of the car.
when released there should be continuity.
or pull the cable from the back of the switch and touch it to an earth on the bodywork, the interior light should light up.
Also check with a volt meter that the cable to the back of the doorswitch has power.
Old Sep 23, 2007 | 07:53 AM
S2000_FUN's Avatar
Thank you shepp your reply.
Is it easy to take the door light switch off? When i saw it, it looks like is quite good attached to the body frame.Is it just unclip it because i could not see any screws over there.
Chris
Old Oct 4, 2007 | 04:05 AM
MacGyver's Avatar
Remove the panel covering that section inside the car (pull up the sill plate first)... one screw, that's all. You can touch the wire without removing the switch (though pulling out the switch is just as easy).
solitarycheese
Oct 8, 2014 08:27 AM
bakalag
May 30, 2010 12:43 PM
AstroPhsx
Mar 5, 2010 06:30 AM
lilmrtinnie
Sep 2, 2009 06:03 AM
jaehoppa
Jun 24, 2007 11:11 AM
