Updated banjo bolt install
Old Oct 5, 2007 | 12:56 PM
TheCarGuy2021's Avatar
Default Updated banjo bolt install
Well I just installed my updated banjo bolts before I put the turbo setup on and I thought I'd clear a few things up for those wanting to do it themselves.
Here is the new bolt, old bolt, and squirter:
Old bolt in squirter:
Bolt is behind the counterweight:
All you do is take out the old bolt. When you take it out, the squirter will come off with it. Put the new bolt in the squirter, start threading the new bolt back into the block. I was told that the bolt had to be "set" correctly, this confused me as for I wasn't sure how you can "set" a simple threaded bolt. Well what I realized is that the bolt is not what needs to be "set" correctly, it is the squirter. As you can see on the left side of the squirter in this picture there is a round "barb".
There is a corresponding hole in the block which this little barb will go in, screw the bolt in with an extension using your fingers until finger tight with the extension. Once you know it is in, you may now torque to 12 lb/ft.
Knowing this tip would have gave me more confidence going into the install, as I was baffled as how to "set" the bolts before install.
The install took me just a few hours and was fairly strait forward.
Hope this helps!
Old Oct 5, 2007 | 01:24 PM
S2KPUDDYDAD's Avatar
Nice This is only for the older 00 to 01 S2000 correct?
Old Oct 5, 2007 | 01:28 PM
highwaystardoritos's Avatar
older 00? whats the vin thats starts in the 00 that needs/recommends the newer bolt?
All MY 00-01 S2Ks have the older ones, mid year 2002 sometime Honda started using the updated ones. Not sure of the VIN though, I'm sure someone else can chime in.
Old Oct 5, 2007 | 01:47 PM
I have a very early 02 and was wondering about the upgraded bolts
Old Oct 5, 2007 | 01:49 PM
thetz99's Avatar
I'll be doing this soon when I put on my baffled pan and tap the oil return in the girdle...thanks for nice close ups If you have more pics, pls post them
Old Oct 5, 2007 | 04:46 PM
NVMY4N's Avatar
Added Link in FAQ'd DIY for extra clarification.
Old Oct 5, 2007 | 05:50 PM
Found it! Honda began installing the new design bolts after engine F20C 1102 5386.
Old Oct 5, 2007 | 07:48 PM
My car is the 1659th car off the line in 2002 so I guess I will be doing the same thing
Old Oct 5, 2007 | 08:38 PM
Cyl #1 is a PITA!
