Updated banjo bolt install
Old Oct 6, 2007 | 03:17 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
That engine number is inaccurate. I went by that number for a long time till I found an 02, slightly earlier number, that had the new bolts. He's the original owner and wanted them done.
He'll be here today for a TCT, I'll post the engine number later.
Old Oct 6, 2007 | 06:19 AM
TheCarGuy2021's Avatar
Old Oct 6, 2007 | 06:27 AM
S2KPUDDYDAD's Avatar
I'm guessing this can be done with the engine still in the car?
Old Oct 6, 2007 | 06:42 AM
TCT or banjo bolts? Either way, both can be done with the engine in the car. TCT is a breeze.
Old Oct 6, 2007 | 06:45 AM
Thanks, I know that the TCT can be done
Old Oct 6, 2007 | 06:46 AM
For the banjo bolts you just remove the crossbeam going across the underside of the oil pan, remove the a/c compressor, and then take out the gajillions of bolts holding the oil pan on.
Old Oct 6, 2007 | 08:04 AM
Soul Coughing's Avatar
cyl one is annoying because of the oil pump! A very important install for anyone who is even thinking of FI
Old Oct 6, 2007 | 08:45 AM
Billman250's Avatar
Top Answer: 1
Yes this update is a must for FI applications. I have seen two engines score the #4 cyl immediately after FI install.
Old Oct 6, 2007 | 08:51 AM
happened to my motor, within one of hour of FI
Old Oct 6, 2007 | 09:35 AM
Wow I have no plans to go FI but don't want my engine going cabooom
