Berk Technology 50mm Exhaust Manifold Group Buy #2
THIS IS THE OFFCIAL GROUP BUY #2 FOR OUR S2000 HEADER.
GB SOLD OUT.... Thank you!
Specs & features:
HPC Ceramic Coating Inside & Out (or polished stainless)
True 50mm primary header
True 63.5mm exit
True SUS304 stainless steel, flanges, & tubing
True 1.6mm thick wall tubing
Silicon bronze welding rod at the flanges for ultimate fatigue resistance
Secondary wide band port for EMS tuning (plug included)
~11.5lbs (stock is ~23lbs)
This coating is good to 1600F and will not discolor, flake, or scale like the silver coatings do. GREATLY reduces skin temp of the header itself and reduces underhood temps. Great for you guys in hot & humid climates.
Our header will mate perfectly with our 2.5" test pipe, or our new 2.5" high flow metallic cat.
On the AP1 test car we were able to pickup a max of 6HP & 6TQ to the wheels with the addition of our header and our test pipe. (see details below)
On the AP2 test car we were able to pickup a max of 5HP & 5TQ to the wheels with the header only. (see details below)
I have several other 3rd parties on S2KI reporting midrange gains of 10 wheel HP with the addition of our header alone.
Our header stands true to our mantra of dyno proven & track tested products without the "JDM" price tag. You will see REAL gains with our header, not just a lighter wallet.
Dyno #1
AP1 (2003)
38K Miles
Baseline Conditions:
Spoon Replica Air Duct
K&N Drop in replacement filter
Test Conditions:
Berk Technology Prototype 50mm header
Berk Technology V2 Test pipe
Some notes about the runs. The stock ECU is very good at adapting to changes in engine VE. When you start out with a change, you'll see the changes in the motor with a richer A/F. With the richer A/F the car will actually loose power. What we had to do was load the car on the dyno and make several passes. As you make more passes, the A/F curve will lean out and bring you back to the same A/F curve that you began with. Once you have the same A/F, this is where you stand as far as power goes.
Excellent gains in torque throughout. Torque gains consistent both on & off VTEC engagement.
Good HP gain down low, even better with VTEC engagement.
Dyno #2:
AP2 (2004)
25K Miles
Baseline conditions:
J's Racing Tsuchinoko Intake
T1R 70mm Exhaust
Test Conditions:
J's Intake System
T1R 70mm Exhaust
Picks up lots of torque (for a S2000), excellent increase in area under the curve.
ORDER HERE!
Shipping will be calculated based on your zip. The website will give you your shipping rate before checkout.
Thanks for the support guys!
Bryan
Phone: 949-716-0544
Email Contact: bryan@berktechnology.com
Web: www.berktechnology.com
Specs & features:
True 63.5mm exit
Dyno #1
AP1 (2003)
38K Miles
Test Conditions:
Dyno #2:
AP2 (2004)
25K Miles
T1R 70mm Exhaust
Test Conditions:
J's Intake System
T1R 70mm Exhaust
ORDER HERE!
Bryan
Phone: 949-716-0544
Just placed an order for the high flow cat....Received the header yesterday and I must say it is a really nice looking piece. Definitely lighter than the stock header for sure. As soon as I get the cat I am gonna run up 200 miles so I can get it dynoed...Will let you guys know the results!
..... Hey Bryan where is the exhaust to go with the header and cat?
I'll have some pictures & vids up of the car shortly.
A little info on the exhaust. We've dubbed it the Berk UHV exhaust, I'll tell you what it means tomorrow.
100% Titanium mufflers, not just the tips!
Each can weighs 3.5 lbs!
Dual muffler
HUGE weight savings. Forgot to put it on the scale, but it's roughly 1/2 the weight of the OEM system.
Ultra High Volume?
A friend of mine said that ceramic coating falls of easily in our winter (lots of slush and snow and salt on the roads). is it true? have you had any feedback concernig this problem?
