Rear Control Arm Bushing
Old Dec 9, 2007 | 06:58 AM
SpitfireS's Avatar
Default Rear Control Arm Bushing
The adjuster bolts of the rear control arms (both) will not come out.
One of the bolts does not turn at all, even afer a fair bit of penetrating fluid (not WD-40 )
It looks like the bushings are a bit damaged too.
I think I can get a hacksaw blade in there to cut the bolt on both sides.
That would remove the arm but leaves me with even more damaged bushings.
Are those rear control arm bushes replaceable?
On the San Leandro parts list I can't find a seperate bushing, only the arm itself and the bolts, etc.
Help
Old Dec 9, 2007 | 09:47 AM
negcamber's Avatar
OEM AP1 bushings are not sold separately. You can buy Mugen or Spoon bushings for the AP1, but that is very expensive...cheaper to buy new a-arms.
Old Dec 9, 2007 | 10:34 AM
Shopman's Avatar
You can get them here:
Powerflex
They have a US distributor too
Old Dec 9, 2007 | 12:39 PM
negcamber's Avatar
^^ Nice find! Thanks!
Old Dec 9, 2007 | 12:46 PM
jzz30's Avatar
the bushing dont cost that much. like 70 something dollars for the mugen bushings.
Old Dec 9, 2007 | 01:04 PM
RadioZero's Avatar
thanks!
oh and neggie, are you going to order some? if so, let me know what you think.
TIA
Old Dec 9, 2007 | 02:10 PM
SpitfireS's Avatar
Shopman Posted on Dec 9 2007, 09:34 PM
Thank You!
Thank You!
Thank You!
UK > The Netherlands should not take that long.
Old Dec 9, 2007 | 07:30 PM
jyeung528's Avatar
is it accurate to say that everyone will need to replace these bushings at one point or another...meaning it is a given that they do wear out at some point?
there was a thread where the only option was to replace the lower control arm...but now powerflex.com seems to be the obvious answer.
Old Dec 10, 2007 | 04:56 AM
Shopman's Avatar
I removed all mine and greased them with copperease(anti seize compound) when the car was 10 months old.
There were already signs of corrosion as Honda do not apply any grease when assembling these parts
The Powerflex bushes are Polyurethane not rubber so are uprated compared to standard rubber.
One thing to remember is that Powerflex do not have a Castor bush available at this time.
If you need these you will have to buy them from Mugen or Spoon.
The castor bush is often the one that does seize because of it's position taking all the spray from the front wheel. This bolt is in a sleeve too, so the bolt can seize to the sleeve and the bush.
In the UK we have found seizures on older cars becoming quite common.
We have also found that putting the alignment in spec after greasing transforms the car's handling.
The way they come out of the factory can definitely be improved upon.
We get more rain than you guys in Florida so more seizures I guess
Castor bush
Old Dec 10, 2007 | 01:51 PM
SpitfireS's Avatar
Shopman Posted on Dec 10 2007, 03:56 PM
No need to rub it in
That bush is next on my list.
Caster is "in UK spec" now but there is some difference between left & right.
It didn't hurt on the track or I didn't notice (more likely).
Not that I'm a track junkie, been there only twice.
Honda really needs to use some moly lube (never seize) on those bolts.
Finding out after almost 8 years is tooo late
