Sponsored by:
Sponsored by: CARiD
Megan Header owners
Old Jan 2, 2008 | 07:16 PM
S2KVITO's Avatar
Default Megan Header owners
I installed mine and noticed that the o2 bung is just bearly touching the heatshield under the car. Is this normal? I think this is where the vibration is comming from at certain RPM's. Im thinking of putting a piece of header wrap behind it. What do you guys think I should do?
Old Jan 3, 2008 | 09:07 AM
CrankDatVtec's Avatar
how do you like the headers any diffrence??
Old Jan 3, 2008 | 09:25 AM
jirro22's Avatar
give it a shot i did yhe same thing on my TP...and / or trim a litle bit of the heat shield to clear some space..it should work...i had same issue but on my test pipe instead, its rubbing a bit and makes a rubbing sound on a certain lower rpm, so i trim that portion thats rubbing and i wrap it with heat wrap...its all good now....good luck....
Old Jan 3, 2008 | 01:15 PM
S2KVITO's Avatar
This header is only for the AP1 I have it on my AP2 it rattles the hell outta me lots of vibration
Old Jan 3, 2008 | 03:00 PM
luisS2K's Avatar
i have the header installed for like 8 months now and it have never rattled or vibrated!!!!! i have an AP2 2005.
Old Jan 3, 2008 | 03:09 PM
luisS2K's Avatar
the header didnt gained much but it weights a lot less that the stock one. my car gained only 1whp over stock. before header the car had AEM V2 intake and a homemade testpipe no tuning done on it. it was on a dynojet with temp at almost 90 degrees.
Old Jan 12, 2008 | 07:14 AM
jphish's Avatar
I'd like to see the dyno.
Here's my dyno sheet with the megan header. Before and after
Old Jan 12, 2008 | 05:11 PM
KnowledgeIsPower's Avatar
my header wont even install because the bung is in under body. ive ordered new bung online and will having a shop weld it in a better position for me. im not gonna mess around with it.
Old Jan 12, 2008 | 08:36 PM
iDomN8U's Avatar
More info plz
Old Jan 12, 2008 | 08:52 PM
jphish's Avatar
PM'd
