Hondata Kpro
Old Jan 21, 2008 | 05:22 PM
civicsleepa's Avatar
Default Hondata Kpro
So a few weeks ago I opted to go out and get the K-Pro for my rev hard boosted s2k. Just to let you know I have a 02 s2000 with a rev hard turbo kit (Gt 30). Anyway the reason for this post is it seems that there aren
Old Jan 21, 2008 | 05:41 PM
JustinC's Avatar
good to hear, I am planning on going this route. I am going to figure out how to use the RSX wideband so that I can use the boost cut and lean cut issues.
Old Jan 21, 2008 | 05:48 PM
i think it is just as simple as installing the 02 sensor for a rsx type s years 02-04 and connecting the wires. here is the part number
36531-PRB-A01
Old Jan 21, 2008 | 05:58 PM
chairmnofthboard's Avatar
Screw you EMS is god! lol jk,
good write up.
What's the difference in valve covers?
BTW love your wheels.
Old Jan 21, 2008 | 06:00 PM
Enthralled's Avatar
I have no problems starting up with my Emanage Ultimate. she starts right up on the first crank.
Old Jan 21, 2008 | 06:01 PM
JDM_EM1's Avatar
just curious but why do you need a new valve cover?
Old Jan 21, 2008 | 06:03 PM
Nick32's Avatar
good write up! I will also probably be going with the kpro unis since it worked so well with my k20r civic.
Old Jan 21, 2008 | 06:48 PM
ThatPreludeGuy's Avatar
If you dont mind what was the rough cost of swap, install, and tune? I've thought about doing this using Jeff Evans to tune it just so I know my car is running the best it can AND be OBD-II compliant. I was figuring somewhere around $2000-2200, sound right?
EDIT: WOW, its looking more like $3k (all parts and tune), if I spent that much I'd want to up the boost too so that's not happening.
Old Jan 21, 2008 | 07:22 PM
Asura's Avatar
The cam sensors are different for '06 and up.
You cannot beat Hondata on so many levels. It's easy to tune the K-Pro and it has many features that make using it a no brainer as far as a standalone for the S2000.
It should be the first choice if the additional cost is with in your budget.
-Asura
Old Jan 21, 2008 | 07:33 PM
JustinC's Avatar
36531-PRB-A01
yeah, but it has to be soldered on the board, there are no pins for the wideband input. also, you have to install a relay to work the heater element on the O2 sensor.
