Upper control arm mount welding
Old Apr 13, 2008 | 02:23 PM
ScottnHeidi's Avatar
Default Upper control arm mount welding
I need to get the mounts welded on my MY2000. Anybody have any experience with a shop locally? I'm in Silver Spring, MD.
Thanks
Old Apr 13, 2008 | 02:44 PM
w1ngman's Avatar
You need them welded because they're broken? Sorry, while I'm curious as to your intentions (vs. replacement) I'm afraid I have no welder referral to offer you.
- Dave
Old Apr 13, 2008 | 04:15 PM
Large diameter front sway bar, sticky tires and autocrossing/racing can cause the rear mount on the front upper control arm to start to separate at the spot welds.
Good pictures on this site:
http://www.pbase.com/rsrock/aarm
I think there is a TSB on this topic from several years back and some discussion years ago about whether the welding would be A Stock legal if there was no Honda directed repair.
https://www.s2ki.com/forums/index.php?showt...0&#entry6525583
Tech Line Summary Article
ATS040809
Pop noise at front upper control arm mount
Applies To: 2000-2004 S2000
If an oil canning or popping noise is heard when cornering or braking hard, visually inspect the frame rail where the front upper control arm-mounting bracket is spot welded to the frame rail. This problem only occurs to vehicles that have been driven repeatedly on a racetrack or in autocross events. If there is a gap
between the mounting bracket and the frame rail, use the following repair procedure:
Old Apr 13, 2008 | 05:53 PM
Hobbs5313's Avatar
Subscribing. Might need this done on my car down the road.
Old Apr 14, 2008 | 08:54 AM
TubeDriver's Avatar
It is a very basic type of job so any decent welding shop can do it. I already have reinforced A-arm mounts but if I had an AP1 I would consider taking it to Piper Motorsports.
Old Apr 14, 2008 | 09:01 AM
WhrDLMI's Avatar
That is actually what I was thinking. I also found a place near Brunswick, Maryland called Fast Lane Fabrications.
It is good to know that AP2's don't typically suffer this issue. Thanks, Pete!
Old Apr 14, 2008 | 03:18 PM
s2kAtTracks's Avatar
wow, This is something I need to check.....Maybe this is the noise I keep hearing
Old Apr 17, 2008 | 06:09 PM
I got the welding and refinishing done at FunKtion Auto in Dulles. Apparently the sheet metal had started to tear, not just the spot welds breaking. They painted and re-undercoated as well. I didn't think it would make as much difference as it seems to have made in the feel of the car. Could just be in my head. They got it done in a day for me. Now I've got 1 less excuse for doing crappy this weekend at FedEx.
iamatlas
Jun 12, 2014 07:59 PM
turbo8765
Aug 13, 2010 11:37 AM
captain_pants
Aug 12, 2007 09:56 AM
