Problem with eManage Ultimate
Old Apr 25, 2008 | 06:06 PM
SoCalIsMyLife's Avatar
Default Problem with eManage Ultimate
I just finished wiring in my friend's Emanage Ultimate. I triple checked all the wiring and set the parameters according to this thread:
https://www.s2ki.com/forums/index.ph...ic=408667&st=0
The car started and idled fine the first time. No problems whatsoever. When I tried starting it for a second time, the idle got really bad and you could smell tons of unburnt fuel. After rechecking the settings, I started it for the third time, and the car would barely even idle. The fourth time it won't even start.
Does anyone have any idea what could be going on? I currently have the injector and ignition maps enabled but everything at 0. I previously tried disabling all maps and that didn't work either.
Old Apr 25, 2008 | 06:25 PM
o'malley_808's Avatar
Did you change the injectors?
Old Apr 25, 2008 | 06:44 PM
crav3s2k's Avatar
no we didn't change the injectors
Old Apr 25, 2008 | 06:58 PM
When you re-checked your wiring did you thoroughly check it? I had the same problem with my emanage and turned out one of the wires got mixed up and was supplying fully power to an injector just dumping fuel and my car would barely run.
Old Apr 25, 2008 | 07:10 PM
crav3s2k's Avatar
well, if the wires weren't input correctly, i would assume that the car would have this problem starting the first time. The first time we started everything ran fine. Any ideas?
Old Apr 25, 2008 | 07:46 PM
MugenRioS2k's Avatar
posted some stuff over here
https://www.s2ki.com/forums/index.ph...&f=47&t=590562
Mods these two threads need to be merged plz.
Need as much info as you can provide on how the car is modded and if some other part was also changed at the same time as the ULT went in.
Any current CELs or Pending CELs
Old Apr 25, 2008 | 08:08 PM
crav3s2k's Avatar
just finished installing turbo kit. need to tune, reason why we installed emu. had a cel, but not exactly sure what for.
Old Apr 25, 2008 | 08:30 PM
TRBOKEV's Avatar
I had the same problem. One of the previous soldered wires for the map sensor from my comptech map clamp came un soldered. I found the wire and re soldered and was fine. A second time it happened also and the problem was the vacuum line to the map came off.
Old Apr 26, 2008 | 06:24 AM
It really sounds like your car is loading up with fuel and would get progressively worse, if your positive that all your wiring is fine maybe look somewhere else...Did you upgrade your fuel pump? FMU? Fuel pressure?
Old Apr 26, 2008 | 07:08 AM
crav3s2k's Avatar
upgraded fuel pump walbro255 and no fuel pressure regulator.
