TP Cel light?
Old Aug 30, 2008 | 07:49 AM
kylemonster85's Avatar
Default TP Cel light?
I just installed a invida 60mm tp with built in cel fix, we put it on and started up the car it didnt throw a light. I drove it for about 45miles then the cel came back on?? What should i do to get rid of the cel?
Old Aug 30, 2008 | 07:56 AM
boostftw's Avatar
take it to autozone and clear the code or unplug the battery, however the code will come back again. to get rid of the code get an Anti-Fouler for the tp
Old Aug 30, 2008 | 07:58 AM
s2k aok's Avatar
diagnose what exactly is the code for the check light, could be related to something else. maybe a quick fix would be to just disconnect the battery (if that works) or use an obd2 scanner and just erase the code...
Old Aug 30, 2008 | 07:29 PM
frofro24's Avatar
Don't disconnect the battery, just pull your back up fuse (7.5amp) in the cabin, this will reset your ECU and clear your CEL. If it comes on again it might be worth having it read, it might be something not associated with your O2 sensor.
Old Aug 31, 2008 | 08:20 AM
do i pull it out while the car is on or do i do it with it off then start it with it out?
Old Aug 31, 2008 | 12:12 PM
frofro24's Avatar
I always have my car off when I do it, and don't start it when it is out, replace the fuse before restarting.
Locate the fusebox, its above your left foot if you are sitting in your driverseat, the fuse you are looking for is the 2nd fuse from top (3rd slot from top). It's the 7.5A fuse that's right between a 15A and a 7.5A. Its marked "Back Up". Now pull out the fuse with the removal tool (if necessary), wait about 15 seconds with the fuse out. Now you can put the fuse back in and start your car.
tubbs
May 20, 2013 09:53 AM
JMP
Apr 4, 2008 03:25 PM
HotDamnitsDavid
Sep 29, 2007 12:29 AM
folex187
Nov 11, 2005 02:35 AM
tru
Sep 15, 2004 06:26 AM
