HELP! engine swap
Old Oct 14, 2008 | 02:29 PM
armthehomeless's Avatar
Default HELP! engine swap
Swapping 2.2 into ap1
No spark,
no fuel pressure, pump wont pump.
pump used to pour gas allover my engine bay every time I turned it on before new engine was installed. now nothing.
something with the computer?
Any suggestions will help....
Old Oct 14, 2008 | 02:33 PM
03AP1's Avatar
I believe there is one ground for spark/PGM-FI, etc.. G101 bolts to the back side of the head nearest firewall. GL .
Old Oct 14, 2008 | 03:00 PM
ground is hooked up, No signal sent to fuel pump at all. so not injector problem.
Old Oct 14, 2008 | 03:15 PM
03AP1's Avatar
Have you checked for voltage back at the pump when you initially turn key to on to energize it?
Old Oct 14, 2008 | 05:02 PM
Yea, nothing.
Old Oct 14, 2008 | 06:38 PM
kial007's Avatar
Have you checked the fuses?
Old Oct 14, 2008 | 07:10 PM
chris_barry's Avatar
Are there any differences in the FC22 and FC20 crank /cam angle sensor triggers?
Old Oct 14, 2008 | 07:44 PM
Slows2k's Avatar
06 and later car use different cam/crank sensors.
Old Oct 14, 2008 | 09:02 PM
03AP1's Avatar
fuse 46 in main fuse box under hood, fuse 2 and 21 in under dash, PGM-FI relay and associated wiring control fuel pump. fuse 2 energizes PGM-FI to energize fuel pump while key is in ON position (not cranked) check fuse, voltage at pin 5 with relay removed, then check for continuity from pin 4 (relay removed) to pin 5 (fuel pump) if voltage is at pin 5. also ck ground for relay (pin 3) and ground for fuel pump.
Old Oct 14, 2008 | 11:10 PM
[QUOTE]fuse 46 in main fuse box under hood, fuse 2 and 21 in under dash, PGM-FI relay and associated wiring control fuel pump.
