HELP! engine swap
Ap1 chopper plates look symmetric.
Ap1 inductive crank wheel. and ap1 inductive sensor
Called Honda tech and he said probably off by a tooth , but they looked right to me.
I'll have the shop its at take another look.
So great news. I drive the car home from the shop..... and i get tapping, then rough idle, then flashing cel it dies....
I pull of the valve cover....
The shop kindly left the little metal valve rocker holders on there. the things you put on so that when you remove the valve train you can easily put the rockers back in the same place.
I remove them and I don't have the right size feeler gauge but i do my best, just to see if my baby will run again...
no such luck. flashing CEL again
Pretty sure its a bent valve in cyl 4. No scan though.......
And it ran great for all of 2 hours. Oversized valves and 2.2 liters sure make a difference.
Also a rather loud humming noise from the intake, don't know if that comes with the bent valve or if it has to do with the ported 1mil oversized valves.
Sadly I don't know how much longer I will be an S owner
